HPOP reservoir and air bleed - Ford Powerstroke Diesel Forum
Old 12-03-2012, 01:14 PM
where is the hpop reservoir on the 6.0 and what the best way to bleed the air out of the system?
Old 12-03-2012, 01:22 PM
Unapologetically American
Feedback Score: 4 reviews
The reservior is on top of the motor, between the heads, in the 'valley'. Why do you need to bleed air out?
Old 12-03-2012, 01:30 PM
its a long story best way to fill you in would be to have you read my last thread titled no start but has 1400 PSI. where do i check the level and /or fill the reservoir?
Old 12-03-2012, 02:29 PM
MAD - Modification Addict
Feedback Score: 8 reviews
If you have 1400 psi cranking than you don't have a hpo leak and you should start looking elsewhere for your problem. I assume your usinge a monitor or daliagnostic software to read the icp pressure. See if it can tell you whether or not your getting FICM sync.
Old 12-03-2012, 02:48 PM
I assume that you didn't read the other thread but just the title huh? Read it and get back to me please I need all the help I can get.
