vgt solenoid bad? Low boost
I can't get over 20 psi of boost at full throttle. Would a bad vat solenoid cause this, or is there maybe something else going on? Thanks for the input in advance!
I have an 04', I was only getting 19 or so, snd it was lagging. Yesterday I pulled my turbo and cleaned it, much better throttle response, if I dog the chit out of it, I can see 24lb. But it is running up to 20lb consistently. If I hook a load up, i'm sure i'll see close to 26lb, i've seen it once before cleaning at wot. My monitor readings for the vgt% are correct now, much quicker spool up time.
Sent from my phone that somebody didn't help me get. Last edited by southend; 11-24-2012 at 02:37 PM. |
Are you running a tune?
No, i'm not, that would probably make a difference.
Sent from my phone that somebody didn't help me get. |
I'm runnin quick trick's looney and still can't get over 20 psi. It just doesn't seem right. Do you think I oughta pull my turbo and clean it?
take it out and clean it... worth your time even if that's not the problem, but it most likely is, unless you have a leak somewhere
