First I want to say thanks for taking your time and reading my thread, any advice is appreciated in advance
![]() So I purchased a 07 6.0 a few months ago, I knew of the egr and oil cooler problems before purchase, as well as turbo and injectors issues.. Within the past few weeks only at ideal do I get a cloud of white smoke, and very strong fuel smell. it happens pretty irregularly but you can expect it after long trips with no load. I recently had a 2 axle 6 * 9 trailer hooked up to it, followed by about 3 tons of gravel in the bed and all you saw was smoke and smelt fuel... *It will smoke until I cut the truck off. I figured it was the injectors so I took it to the dealership to have it checked but it still isn't throwing any codes. There hasn't been any coolant loss, plus it doesn't smell like coolant. I'm thinking either injectors or turbo seals, but but there is also a head gasket concern. Although with no codes fords warranty will not cover any work so what should I do??? I'm half way tempted to put an extreme load on it and drive the piss out of the truck until I get a code.. lol I know that's pretty ignorant but I know something is wrong I just can pin point the issue. Truck does not miss, starts great, and runs with nothing held back, turbo pressure seems fine. Please note that I do not have any computers hooked up to it to monitor exaust temps, oil and water temps.. Thanks again for your input and I hope everyone had a great Thanksgiving! |
You need a monitor, load test your batteries and perform the ficm check procedure. Could be a ficm problem, with no code.
Sent from my phone that somebody didn't help me get. |
thanks for your time southend, i just had it in the dealership for the issue i described i don't know if they tested the ficm in anyway but the battery load is where it should be. i know i need a monitor i just cant dish out the cash right now
they couldn't find anything while it was in/ funny how it acts up but when you take it in everything is clear lol/ they did tell me that if at any point it is blowing smoke just bring it in and they'll put people on it. the only problem is every time i'm near the dealership the damn thing isn't blowing.. i had it in just last week, that day it did nothing but since then it's been a little more regular and a little less sporadic.. if your interested i will let you know what comes out of it.
Definetly keep us updated, it helps us all. I hear you about the funds, the scanguageII is $160, when you can swing it. Then the money you might spend at the dealer is money you can spend for yourself. The ficm need to be checked cold with a monitor, by the time you run it to them, the condition is not the same. The monitor could help you catch it as it happens. Ford has failed at these engines, not talking about all the good techs out there. Ficmrepair.com has some good info.
just in case you check the ficm there here is a vid that goes into depth.
Thank God for youtube. |
