LONG CRANK - Ford Powerstroke Diesel Forum
Old 11-21-2012, 02:55 AM
LONG CRANK
HI GUYS
I KNOW THIS IS ON HERE SOMEWERE AND I HAVE BEEN LOOKING
BUT HERE IT IS I HAVE A 2006 6.0 RECENTLY IT HAS A LITTLE LONGER CRANK IN MORNING BUT DOES START I HAD FICM CHECKED AND VOLTAGE IS FINE BUT NOW YESTERDAY WHEN TRUCK WAS UP TO TEMP FROM DRIVING I SHUT OFF RAN INTO STORE CAME OUT WENT TO RESTART AND CRANKED LONGER
AND WAS HARD TO START KINDA LIKE ROLLED INTO STARTING WHILE CRANKING
THINKING IT MAY BE STC FITTING
ANY HELP
RECENTLY TOOK TO FAYETVILLE FROM ILLINOIS AND BACK ON A TRIP RAN GREAT
TRUCK HAS 110000 POWERMAX TURBO 4 INCH TURBO BACK CAT AND MUFF DELETE OIL BYPASS FILTER
Old 11-21-2012, 03:44 AM
"HAVING YOUR FICM CHECKED" IS NOT ALWAYS THE SAME AS YOU CHECKING IT CORRECTLY. YOU NEED A MONITOR. LOAD TEST YOUR BATTERIES AND PERFORM THE FICM CHECK PROCEDURE WHEN IT IS COLD. IT ALSO SOUNDS LIKE YOU MAY HAVE THE START OF A HPO LEAK. WITHOUT A MONITOR ALL THIS IS GUESSING.
BTW, it is not necessary to type in all caps........
Sent from my phone that somebody didn't help me get.
Old 11-23-2012, 06:19 AM
thanks and sorry about caps lol wasnt paying attention will check batteries
but warm start issue probably a hpop leak
Old 11-23-2012, 07:22 AM
Yea, I was just jerkin your chain. Warm hard start is usually the start of stc, dummy plugs, and standpipes leaking, any or all three.
You need a monitor, you should be able to see all that.
