ICP sensor reading circuit low - Ford Powerstroke Diesel Forum
Old 11-17-2012, 11:07 AM
New to diesels and my check engine was reading it had a bed ICP sensor them it goes off but the truck isn't running like it should so.i have it checked again and it reads ICP sensor circuit low. Also my mpg have dropped a lot. Do i need a new ICP sensor or would it be something else?
Old 11-17-2012, 01:56 PM
Powerstroke Techie
Feedback Score: 3 reviews
what year?
Old 11-17-2012, 04:07 PM
Unplug it from the pass. side valve cover,see if it runs better,may just be cruddy pigtail. or could be an internal leak.
Old 11-17-2012, 07:57 PM
03 and early 04 the icp is under the turbo on the hpop pump cover. Which is probably why sinner wanted to know what year he had. The test is valid for either location.
Old 11-18-2012, 09:59 AM
It's a 05 I'll try unpluging and see if that helps and what do you mean by internal leak?
Old 11-19-2012, 04:23 AM
He means hpo leak, stc fitting, dummy plugs, standpipes. Common on 05 MY.
Sent from my phone that somebody didn't help me get.
Old 11-19-2012, 08:53 AM
Ok I'm new to diesels and don't know what any of the things you mentioned are. Would any of these that you mentioned make it feel.like it's missing out
Old 11-19-2012, 10:25 AM
Go here and download the 6.0 coffee table book.........http://www.forddoctorsdts.com/
You really need a monitor, go to the top of each 6.0 section and read the stickies.
Those things may or may not cause a miss, a bad icp sensor will.
Old 11-19-2012, 11:47 AM
Go here and download the 6.0 coffee table book.........Diesel Technician Society
What are some good monitors for the money
Old 11-19-2012, 11:49 AM
Slacker
Feedback Score: 4 reviews
Scan Gauge II or the Edge Insight CS/CTS.
