Bad hpop?? - Ford Powerstroke Diesel Forum
Old 11-15-2012, 01:58 PM
Bad hpop??
Would a bad hpop cause a no start?....pulled out pressure sensor out of valve cover cranked.no oil came out....need helppp
Sent from my DROID RAZR using AutoGuide.Com Free App
Old 11-15-2012, 02:22 PM
Illiana Chapter Director
In short, yes, a bad HPOP will cause a no start. Gotta do a lot more testing before you assume HPOP though. What year truck? Miles? Complete no start or only when hot?
Old 11-15-2012, 03:44 PM
2007 6.0 with 116000 i did head studs egr.delete ect.. Put it back together...no start bad icp sensor...i have good fuel pressure but no oil pressure...like i said no pressure on The valve cover sensor
Unbolted the sensor cranked the motor no oil came he out of the Sensor hole...
Old 11-15-2012, 03:47 PM
MAD - Modification Addict
Feedback Score: 7 reviews
Have you checked lpo system?
Old 11-15-2012, 03:52 PM
define ipo please
Old 11-15-2012, 03:53 PM
Low Pressure Oil System.
Old 11-15-2012, 03:58 PM
What are the steps to address that?
Old 11-15-2012, 06:28 PM
Don't u have to crank for a long time to build pressure back up after messing with the oil system?
Sent from my PC36100 using AutoGuide.Com Free App
Old 11-17-2012, 05:05 AM
Yes you do.
Old 11-17-2012, 05:45 AM
Put a battery charger on it and get to spinning the starter. Don't over heat it, maybe give it an 8 to 10 second spin followed by the same time of cool down. If you want, you can jump the starter from the pass side fender and watch your ICP hole. Some bleed the air pretty quickly, others will make you think that you left something unplugged.
Sent from my DROID X2 using AutoGuide.Com Free App
