Replacing injector... Looking for advice. - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-14-2012, 06:27 AM Thread Starter
I have an 05 6.0. It has an intermittent rough idle, a miss can be felt at 1500 rpm under load and it chugs pretty good during warm up. Cyl # 4 is not contributing correctly. It has been this way for about a year and each time the oil is changed the problem goes away only to return after about 1000 miles of the change... I'm pretty sure changing #4 injector will solve the issue.
My question is what else should I consider doing while the D/S valve cover is off?
Thanks!
Doug
dkrage is offline
post #2 of 10 Old 11-14-2012, 06:37 AM
Quoted: 364 Post(s)
Feedback Score: 5 reviews
Dummy plugs and stanpipes very commmon issue for a no start while hot symptom. If you don't have it now, might as well prevent going back under the VC in 6 months!
They are screwed into the High pressure oil rails under the valve covers!
Also, how much are you paying for that injector?
If it was me, I would call up Warren Diesel, Or Renegade Diesel and get a full set of injectors to replace all 8... It will run MUCH better will only cost you $500-750.
If you just do one, all the others are getting tired too, so another one might go out 3 months down the road!
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is online now
post #3 of 10 Old 11-14-2012, 10:26 AM Thread Starter
Thanks for the reply Eli!
I was thinking of only doing the one because the pass side is going to be a pain. (There is an add-on hydraulic pump & hoses on that side)
Although, at the price you mentioned, it really does make sense to do all of them. This way all dummy plugs and stanpipes could be addressed.
I have not looked into pricing the parts yet but was guessing the injectors might be close to $300.00 ea.
I will give a shout to the places you mentioned...
Thanks again!
dkrage is offline
post #4 of 10 Old 11-14-2012, 10:58 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Like Eli stated do at the very least all the injectors in that bank as well as all dummy plugs and standpipes should be addressed as you have to remove them anyway to pull out an injector. I would definitely get ahold of Jesse or Sheldon and get a full set and do them as well as all standpipes and dummy plugs as mentioned. Also while your in that far you might consider an egr delete and updated stc fitting as it wouldn't be to much more work to get those knocked out of the way while your at it.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 10 Old 11-14-2012, 11:11 AM
Quoted: 364 Post(s)
Thanks again!
No Problem
I agree... If you want to take the center section apart to get there do it... But just for valve covers/ injectors, it is not needed to take off the turbo and misc items there.
Up to you Dkrage what you decide to do there
Studded and Deleted
post #6 of 10 Old 11-14-2012, 11:19 AM Thread Starter
Thanks!
I did the EGR delete, oil cooler and stc fitting a couple years ago... (best thing ever for this engine!) I should be good to go from that standpoint.
dkrage is offline
post #7 of 10 Old 11-14-2012, 11:24 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
You are correct. I was oh suggesting that as you don't have a list of mods done to the truck. Do you have a monitor in the truck? If not let me know I can be you hooked up!
Bryan @ Stealth Automotive
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #8 of 10 Old 11-14-2012, 11:46 AM Thread Starter
Thanks Bryan!
It's a work dump truck and aside from the EGR delete I have kept it stock. Do you think I should still look into a monitor? I guess I might be interested...
dkrage is offline
post #9 of 10 Old 11-14-2012, 11:53 AM
Quoted: 364 Post(s)
I would strongly suggest it. Maybe even before you tear into it to see the health of your oil cooler... might be plugged up without any visible symptoms.
Or your ficm volts, or battery health.
Studded and Deleted
post #10 of 10 Old 11-14-2012, 12:00 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Yes I would definitely recommend a monitor for every 6.0 owner.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
