Running on 7 cylinders - Ford Powerstroke Diesel Forum
Old 11-13-2012, 04:18 AM
What would cause my #3 cylinder to not fire? Tried a diff injector still runs the same. Tried a diff ficm still the same. Diff pcm still the same. I'm lost, any ideas?
Sent from my PC36100 using AutoGuide.Com Free App
Old 11-13-2012, 07:19 AM
Wiring harness. What codes do you get?
Sent from my phone that somebody didn't help me get.
Old 11-13-2012, 09:10 AM
Wireing or a actual cylinder problem. That said a valve problem would show up as popping thru the exhaust or intake. A broke ring [low compression] would only show up as a miss or excessive blow back, unscew the oil fill and see if it chuffs at ya.
Old 11-13-2012, 09:39 AM
We are thinking alike, thats why i'm wondering if he has any codes. :thumbup:
Old 11-13-2012, 11:00 AM
That's what I thought also. So I swapped a motor I had in that only has 100000 miles. Still does it.
Old 11-13-2012, 01:51 PM
Did you use the same harness?
Old 11-13-2012, 01:53 PM
So you changed a motor, and the harness may be bad?
Old 11-13-2012, 02:40 PM
But I tried a diff injector harness on the other motor still ran like crap. It's the #3 cylinder on both motors its gotta be somthin electrical but I don't even know where to start
Old 11-14-2012, 02:36 AM
I just don't understand how my ficm is good and the harness and pcm and still have that number 3 cylinder not fire on 2 different motors. I haven't drivin my truck in almost a month. It's sad to see it sit there. Does anyone have any ideas?
Old 11-14-2012, 04:33 AM
I think your going to have to dig deep into the harness. Do you have a monitor for live data? Any codes?
