Need help with vacuum lines
Hi got an 06 f250 6.0, im having problems with the vacuum lines, i have had the cab off to do heads and gaskets and i seem to misplaced a vacuum line i have one unhooked off of the vacuum reservoir, also only my defrost is blowing heat and front end is spinning in 2wd, i cant find a diagram anywhere and ive read up a little bit on why its blowing only through the defrost, what i need is a diagram or a picture of exactly what lines go to what. Ive tried comparing to another 06 but the vacuum line went directly into the blower box my has a valve off of the heater core hose with 2 vac lines that go into it everything seems to be hooked up but still have one straggler. A picture would be great thanks
The grey hose goes to the heater hose valve on the hose running across the right valve cover.
Sent from my phone that somebody didn't help me get. Last edited by southend; 11-12-2012 at 06:09 PM. |
this should get you going.
This is what i got going on as you can see i have one line that is not hooked up, im not sure but shouldent that line go to the hubs?
I can take a pic for you this afternoon.
Sent from my phone that somebody didn't help me get. |
Here you go bud.
![]() I think your pluged in upside down backwards, make sure your plug looks like this. Facing the plug. Black on top, red on bottom. ![]() If you are holding the black hose, in your picture, it goes here on my truck, then down to the frame. Sent from my phone that somebody didn't help me get. |
Lol..........hahaha...........rofl.
Sorry bout that......... If I look at your pic, with the grey hose, it is stuck on the valve actuator pin. Take it off, that goes on the end of the little actuator for the heater valve. What looks like you have plugged into the actuator right now, is what i'm telling you to plug the black hose into.......hehehe. Let me know if you need another pic. Sent from my phone that somebody didn't help me get. |
ok if you could upload one of that valve on the heater core hose that would be great it
This is where the grey hose goes....
![]() This is where you have it now..... ![]() The pictures uploaded upside down, and my valve is sideways. Your valve is upright. Sent from my phone that somebody didn't help me get. |
alright i got my lines switched around but i must have a leak because my pump will not shut off. Thanks for all the help
