I need help!!
I have been looking for a tow truck for months. I wanted to buy new, so I didn't have to worry, but that didn't work out. Anyway, I found a 2006 F550 rollback outside of Pitts. PA. The truck has 230k on it but the guy did the studs replaced all injectors, egr delete and some other things that I was worried about he had all the paper work. So I bought it for 22k and while driving home I heard some ticking sounds coming from the engine and then it went away about five minutes later I heard it again and then it sounded like something broke loose and then it made a loud pop and all the oil came out and the truck shut down. I looked under the truck and I saw a small hole in the oil pan. Anyway, I was sick to my stomach luckily my wife was following me. So we had the truck towed to a shop in Crystal Spring, PA called Ficher's. I spoke to the guy and the first thing he said is that I need a motor. I told him that I wanted to have it check to see if it could be fixed without replacing the motor. I don't know what to do, I don't want to put a new or used motor in this thing and have the same issues. So I am thinking just take it to a performance shop somewhere and have them rebuild the motor to where it will not give me any problems and it can handle anything I throw at it. I live in Charlotte, NC. however my mom lives in Laurel Md. So, I need some advise on the best way to handle this, and if someone knows of a good shop in the Maryland area I can take the truck to have everything done right the first time. Thanks, Kyle
You probably slung a rod, as long as the block is not busted it should be rebuildable.
Just to let you know not all peformance shops are familiar with the 6.0. Any engine rebuilder that is familiar with the 6.0 will do you don't nessicarily need a performance shop. The shops eperience level with the 6.0 should be you decideing factor. Call around and get you some quotes from several places. Jasper engine will sell you a rebuilt drop-in motor from 12k$ be advised most rebuilts will be built to stock specifications. No bulletproofing but you can always ask em what a bulletproofed engine would cost and if they will do them. Good luck. To me if you can get the bottom end done and keep your allready done improvements it may be worth your while. Everything will depend on the extent of the damage. |
Yeah, I am hoping that I can get the bottom done, around how much would that cost?
Like I said depends on the damage. Anywhere from 1500 to 3000.00 is about average.
You have lemon laws there? Get your money back.
I think the lemon law only applies to dealers. The guy owns a auto shop so I am going to see if he would fall under this. He said he would give me some money back so we will see. This is just the beginning, I don't have a truck to work so I have nothing but time to call any and everyone on this planet until I get this right. Anyone that knows the laws in Pa. please chime in.
Well , the truck was bought used , no lemon law applies at all . Did he offer a warranty or a guarantee ? If not you are at his mercy as to if he wants to help you or not . Me personally I would give you back about 4 grand in this situation .
Has any of the emmisions equipment been removed from the truck? E.g; egr cooler, catylitic converter etc? If so you can make him return your money and take the truck back because he is legally not allowed to sell that truck to anyone if the emissions equipment has been removed or tampered with.
For instance a few years back I took my brother to pa to buy a pick up and before the seller was allowed sign over the title he had to have it inspected by a state "certified" emissions shop to check and make sure all emissions equipment was present and working properly. |
