Front hub problems....Need help - Ford Powerstroke Diesel Forum
Old 11-09-2012, 05:26 AM
So the other day I was trying to pull out a stump and my 4wheel drive didnt work until i locked my hubs. I tried putting in 4wheel with hubs and auto drove quite a few feet forward and reverse and still didnt lock in. My ac is fine it dont blow through the defrost when i put it in 4wheel drive. I even pulled the vacuum lines off the hubs and tried the 4wheel switch the ac still blows out of the vents not the defrost so i dont think its a vacuum problem. Any help would be great!!! Thanks in advance
Old 11-09-2012, 05:39 AM
pulling the vac line didn't do anything since the command to lock unlock only last a few seconds
did your hubs work ok manually switched to 4x4 ?
did you dash light illuminate 4x4?
Old 11-09-2012, 05:49 AM
Thanks for the reply, yes manually everything was fine 4x4 light comes on 4wheel drive works
Old 11-09-2012, 05:35 PM
Bumping this up
Sent from my iPhone using Autoguide.com App
Old 11-10-2012, 12:43 AM
Send a message via AIM to KOOOPSD
I have the same problem in my 06
Old 11-10-2012, 03:31 AM
Yeah I've been looking for solutions for the fix. I even changed out my hubs from my buddy's truck that 4wheel was working in auto. Still have the same issue and his works fine in auto with my old hubs. I don't know what to try next. I don't want to take it to a dealer unless I absolutely have to.
Old 11-11-2012, 04:24 AM
Does anybody have a solution?
Old 11-11-2012, 04:31 AM
sorry for the delay
you likely have a problem with the ESOF solenoid, a vac seal in the front axle or a broken vac line
Old 11-11-2012, 04:32 AM
if you have a vac tester like a mighty vac that would be the best to isolate the issue
start by applying vac to each hub by using the OEM splice in the vac tube near the knuckles
Old 11-11-2012, 04:41 AM
Ok thanks for the info. I'll give the vacuum pump a try. With the vacuum pump I should hear the hubs lock in right? Just a little more info on my troubleshooting. I turn the key to run position (truck not running) and shift the ESOF to 4wheel hi and low and you can hear the tcase making noise. So by that I'm assuming my ESOF solenoid is working and also dash light comes on as well.
