is my FICM giving up? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 11-06-2012, 02:56 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Yesturday(40*) -I started up the truck and it stumbled twice before starting. Had to retry twice before it took off. Once it did the EDGE was showing alarm for FICM for the first 45+ seconds. Then it went away and ran fine...
This am (40*)- started truck stumbled pretty hard then started,once again ficm alarm. Let it warm up all is fine no codes. Went home did some reading about ficm testing and this is what I got and did.
Found the connectors on Batt not tightened up so I removed them,cleaned them up and tightened them. Batteries are 4-5 months old so I assUme their good.
OAT 66* EOT125* ECT 131* truck has not ran for +/- 60 min
KOEOFF 11.8volts
Cranking 10.8v started fine
Running- batt FICMv
15sec 13.5 46
30sec 13.6 46.5
45sec 13.6 47
60sec 13.6 47
75sec 13.7 47.5
90sec 13.7 47.5
105sec no change
120sec no change.
So was this "test" worthless cause the truck was warmed up? Anything I need to do different in the am on a hard cold start?
As always thank you for you time!!!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 18 Old 11-06-2012, 03:14 PM
southend's Avatar
Yea, cold start is best, your ficm sounds weak. What is the alarm set at? I set mine for 46 v. Less than 46v, better load test your batteries, and expect ficm repair.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 18 Old 11-06-2012, 03:25 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Okay will do a hard cold start in the am. Is a "repair" a decent way to go, or are you better off juz biting the bullet (BPD) and goin new?
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 18 Old 11-06-2012, 03:28 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
I guess thats kinda a loaded question huh...
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 18 Old 11-06-2012, 03:47 PM
southend's Avatar
My opinion is for a repair, ficmrepair.com. I dont drink much coolaid since I grew up.
southend is offline
post #6 of 18 Old 11-06-2012, 04:07 PM
Snake's Avatar
Quoted: 46 Post(s)
You said bullet and loaded in consecutive posts.
But it sounds like you already know the answer to your question.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #7 of 18 Old 11-06-2012, 04:22 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Ya i kinda do but I gotta say with 4 kids,thanksgiving, a birthday and christmas all comin up last thing I needed was another drain on the paycheck.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 18 Old 11-06-2012, 04:24 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
You think Neal would give me one and let me pay it off next year?
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 18 Old 11-07-2012, 05:55 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Charged up the batteries all nite,got up early started the truck up and the cts never came on....un plugged it. plugged it back in it came on. Looks like Ill try again tommorow.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 18 Old 11-07-2012, 06:30 AM
southend's Avatar
Just touch the screen, it will come on, everyone's does that from time to time.
southend is offline
