EGT's wont drop below 500 deg. - Ford Powerstroke Diesel Forum
Old 11-01-2012, 07:39 AM
As the title says, my truck has been idling for 30 min.s or so. I've been having injector issues could that cause temp to not drop? I don't w4ant to shut it off. Oil temp is 179 coolant temp is 174. First time this has happened. I always wait for egt's to hit 350 before I turn if off. Any help would be great, thanks
Old 11-01-2012, 07:48 AM
Also crusing around this subdivision,20 30 mph. im hitting 600-650 and would normally be around 400-450.
Old 11-01-2012, 07:31 PM
I think me and 41 other people dont see a real problem.........
With the exception that your coolant temps are very low.
Sent from my phone that somebody didn't help me get.
Old 11-02-2012, 07:05 PM
Sticky autometer gauge, no real issue. coolant is always with in 12 deg. of oil so I'm not worried about that. when driving coolant is between 180-190.
Old 11-02-2012, 07:10 PM
I am worried Why the EGT's won't drop below 500 at idle after 30 minutes
have any way to dbl check the reading ?
Old 11-03-2012, 11:22 AM
No other way to check. but i tapped on the gauge and the needle fell down to 300 deg. Its the gauge
Old 11-03-2012, 11:34 AM
bumma my tach gained an additional 500 rpm even with the engine shut off LOL
I drilled a hole through the gauge and reset it = fine for 2 years
