fourth serpintine belt this year - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-31-2012, 04:31 PM Thread Starter
jwsland's Avatar
Don't know what going on here but I'm going through belts like crazy. New tensioner and idler put on a month ago. When I have the truck running and I look at the belt from the pass side, down below the crank pully, bottom one has a slight wobble. Not completley solid like the others. Stupid question but is that normal?
06 F.350 Lariat. Daily tower.
Suncoast Trans, MTW Stage 2, Warren 175/75's
Tuned by Tony Wildman- 515rwhp/973rwtq
06 F.550 4WD 12ft Rugby Landscape Body
97 F.350 Reg Cab 7.3 New Trans w/ upg. converter, no cat, AFE intake.
jwsland is offline
post #2 of 4 Old 10-31-2012, 04:52 PM
No not Normal. Serp belts and pullys have to be true. They are not like the old v belts that could slap and twist around with no big problems.
04 Excursion 4in lift
SCT X3 econ tune
Edge insight
Blue spring mod
4in MBRP SS no cat
Adrenaline Hpop
ARP's
Ficm repair with Atlas 40
CCV mod
BPD delete and water pump
need high idle mod soon
Pioneer DD head and 1k amp pushing two 12's and it was good.
averageguy is offline
post #3 of 4 Old 10-31-2012, 05:03 PM
southend's Avatar
Not normal, but maybe this also has something to do with your water pump problem.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #4 of 4 Old 10-31-2012, 05:40 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
with a water pump hub not being true it's much easier to throw a belt because the pulley is smooth.
grab a hold of your fan and see if any of it moves in and out. If the water pump has play in it you should know pretty quickly
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
