TURBO PROBLEM
my turbo cuts out every once in a while. i could be driving normal and the turbo will only boost pressure at higher rpm's. after a little stop and go traffic it kicks back in normally and is fine.
have you checked the fins? might be sticking
Yeah, Get in there and lube them puppies up.. Thats first thing I'd do, take a peek inthere
is that a common problem with these turbos?
whats the easiest way to oil the splines?
It is a fairly common problem on these turbos and you don't oil the splines. Check out this article on how to clean your turbo: FDDTS - Turbocharger Reconditioning
