P0281,p0401,u0100 ???
got my insight today and hooked it up, getting 3 codes, p0281, p0401 & u0100
1. ive read just to leave the u0100 alone and it will go away. please correct me if im wrong. 2. p0401 clean my egr valve? any thoughts? 3. p0281.. i hope i guess that tells me i need a new injector.. i have a siniter coolant filter kit on the way. im looking into getting a egr delete, i would really like to get this, http://www.mkmcustoms.com/completeso...sandsctx3.asp By the way 2006 6.0 |
yes I would clean the egr for starters
the cyl code can be injector or ficm also the other code did u have anything disconnected lately |
The ficm was repaired 1 week ago by ficmrepair, and the voltage is right at 48.5 all the time on my insight. Im gonna pull the egr right now and post up a pic. Yes my batteries were unhooked for almost a full week.. And of corse the ficm was unhooked for the same amount of time.
The link was basicly a complete solutions kit from sinister.. Egr delete,studs,gaskets,oil cooler etc.. It also came with a sct.
Ah it must have only been viewable by you
the random 1000 code is lack of drivecycles and will go away the cyl can be traced down by a Tech to see why the contribution is off MKM seems ok but I would suggest Gearheads for the SCT and tunes |
u may want a EGR gasket kit to play it safe and don't get any cleaner in the topside electronics via the little hole
Yea i had gotten the gasket set a while back. And i think i did get cleaner in there... Not much though
i just turned on the truck see if everything is ok. I did also find some moister in the hole where the egr valve goes, and the egr was surprisingly clean but did have very very little tan colored goo.. Egr delete and new oil filter im guessing? I cleared codes and the p0401 hasn't come back. Just p0281 is still there.
While im probably gonna order the egr delete and oil cooler, what antifreeze would you recommend to use? Im going to be flushing the system.
Any elc with the cat ec-1 rating will be fine.
Sent from my phone that somebody didn't help me get. |
