Help - stranded in bfe
Truck started running bad, felt like low boost. Started getting worse, began stalling. Rpms at idol seemed lower than normal. Pulled over, killed it, then it wouldnt start. Tried a few minutes later, then started up again. Pulled egr wire, currently have dtcs p0403, p0405, p0299. Fuel pressure looks good. Mod volt = 11.0. any ideas? Would a clogged egr make it not even turn over?
What's mod volts?
And where are you? Maybe someone is close. |
FICM? Without your mods and year we are pretty screwed. Also like said above let us know where. There is no such place as BFE to us.
Those are egr flow error codes, the last one is under boost. Check your boots runnin to the turbo, they can come off. Pull the egr valve see if its clogged, clean it and retry.
BFE=winona, mississippi
It's a 2006, with 97k no mods. I've never had any EGR issues....I misspoke...the truck does turn over...but it won't start Would a clogged EGR make it not start? I thought a clogged EGR would make it run rough. Anyway, thanks for the replys guys! |
