Buying a 550 dump - no smoke on start up, little white smoke when warmed up
Wahts up, long time no see but I need a little help from you experienced 6.bro guys
just like the title says, I want to buy a 550 dump truck. 2004 -97k miles - no smoke on start up(watched the mirror when cranking it up cold), but i took it around the block, got up to about 40mph, edge insight was reading approx 189 190 on eot and ect, everything was great til I got back to the yard and was talking to the owner while the truck was still running. there was a little white smoke coming out of the tailpipe when it was warmed up. The owner isn't knowledgeable on the 6.0s but suggested it was because the truck has been sitting for months. Carfax and Oasis say that it had the tank, injectors, and pump done at 40k miles due to the lining of the chassis cab trucks coming loose and clogging everything. warranty ended at 50 k so from then til 97k there is nothing listed but safe to say not much else was done. all fluids and filters recently done. I spoke to 1 diesel mechanic and he said it could be dirty EGR, cracked EGR, or head gaskets. the first two I will buy the truck in a heartbeat ($14k) and do an egr delete and coolant filter but if its heads I dont want to get involved unless its free or damn close to it. the truck pulls hard, sounds great, and isn't throwing any codes. unfortunately I can't get on the highway and wind it out to really read the ect eot since it isn't registered or insured, maybe if I show up with the cash he will let me? just need a starting point to determine if its the heads or the egr. maybe I'm thinking too far into it but I know the 6.0s can be great trucks if they don't blow up and bankrupt you ![]() a pic for motivation ![]() can you say CLEAN |
just spoke to another mechanic, he said watch for bubbles in the reservoir and that there is no other way to tell besides getting into the motor, not what I wanted to hear.
To me when I look at buying a truck is how well will it do the job I want and how bad do I need it as opposed to initial cost and any immediate need for repairs and their cost.
Factor in these costs as opposed to what else may be available and my time frame of need to get it working. In this case I think you need not worry about head gaskets but you can check for combustion gas with the test strips. The light smokeing can well be from sitting up. Hard to judge without being there. |
It will do the job and i do need it but if it needs a week of $5k repairs i might as well go to the dealer and get a new one with a warranty.
What are the test strips? Sounds like a good idea. Sent from my Autoguide iPhone app |
Napa sells some test strips that detect combustion gas. Be shure they are the ones for the gas as they sell some for antifreeze content and ph. There is also a tester thats uses a fluid that changes color when combustion gas is present in the coolant.
You sample the gas in the degas bottle not the coolant itself with the fluid tester. |
Awesome thanks. I'll try and locate some tomorrow
So run the truck, open the bottle and wave the strip around in the air in the bottle?
Couldnt find them at advance. Any brand name? The counter guy had no clue what i was talking about but thats normal haha
Napa is the only place around here and ya have to order em.
