05 F350 - 6.0 with complete bulletproof kit - has run perfect for months-
Sitting at a light shuts off- engine dies Codes- u0105. And u0306 Lost power to FICM PROGRAMMING NOT COMPATIBLE I'm on the side of the road - have checked fuses- wiggled plugs - and cussed and pouted- now I'm ready to fix it- so I can get home Any help would be much appreciated |
Sure am in need of some expert advise
Have my fluke meter ready Someone please tell me what to check NYF350 where are you??? |
Anyone ????????
Sure need help guys FICM- forgot how to check voltage?? Help |
Sorry bro but I got nothing. Good luck though.
Bump to the top.
Sorry bud. I'm thinking |
Do you have a monitor? And when you say complete bulletproof kit what exactly is that?
Studs- EGR cooler - external oil cooler- fuel pressure regulator- water pump-
All from Bulletproof Diesel |
Not sure how much help I can offer (being a diesel noob and all), but FICM voltage with your meter should be the pin/screw closest to the driver side of the truck under the panel on the FICM. 48 volts with key on, cranking, and running.
Monitor? Did you update the stc fitting dummy plugs and stand pipes? Unplug your icp sensor and try to start it?
I have an edge CTS that's it
Fluke meter Any ideas guys - I'm almost out of options - I have power at FICM relay |
