06 spooling and starting issues - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-27-2012, 09:19 AM Thread Starter
I have an 06 powerstroke that has been pretty good for the most part, however I am starting to notice a few issues popping up:
When I start the car when it is cold out or at high altitudes I get a hard start. It will crank for a while and then upon start up the idle is HORRIBLE!!! It feels like a gas motor with a clogged fuel filter.
When I try to give it some throttle under load after I start it, I get NO turbo spool and it just blows a TON of smoke. I even had the truck falter and die once.
I am still getting 20psi on the dummy gauge, and it never runs hot. Did I smoke my turbo? The truck is under warranty, so if anything goes wrong, I want to get it fixed right. BTW, I currently have 71,000 miles on it.
Thanks
Dima
2006 F250 Lariat Stock for now...
1969 FJ40 crawler 60,38,350,400,20
Flatty is offline
post #2 of 6 Old 09-27-2012, 09:24 AM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Pull your codes. Sounds like an injector to me. What color is the smoke? Probably an over fueling or under fuel.
Bluedemon6.0 is offline
post #3 of 6 Old 09-27-2012, 09:31 AM Thread Starter
No codes. Black smoke like crazy. Mind you I have the Innovative tuner tuned to the extreme street. I detuned it back to stock and still had the same isseus.
Thanks again
dima
Flatty is offline
post #4 of 6 Old 09-27-2012, 09:42 AM
Do you have a egr valve? If you do I would clean that. The egr valve will stick and when you shut the truck off it will reset. So you won't have a code.
post #5 of 6 Old 09-27-2012, 09:51 AM
check the icp sensor, fuel pressure, injector contribution test and injector buzz test.
SOOTIE is offline
post #6 of 6 Old 09-27-2012, 04:28 PM
southend's Avatar
Load test your batteries, google ficm check procedure. Do you have a monitor?
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
