6.0 skipping at 70 - Ford Powerstroke Diesel Forum
Old 09-25-2012, 08:20 PM
6.0 skipping at 70
Truck has never give me any problems and has 200k on but now when going down the interstate u get up to 70 and it starts jerking and skipping u lay on in to it and get to 80 and it clears up. No codes truck has studs,egr delete. And this only happens every now and then with and without programmer.
Old 09-25-2012, 08:31 PM
Check your FICM voltage at key on, start up, and running. No less than 48 volts. Other than that must be injectors. Box yours up and call Warren Diesel.(814)-439-0218 They'll fix you up, ask for the powerstroke.org special.
Good luck! We're here if you need us.
Old 09-25-2012, 08:54 PM
Ficm is good and injectors are good
Old 09-26-2012, 01:04 PM
what did you use to test the FICM? And Injectors?
Old 09-26-2012, 01:31 PM
MAD - Modification Addict
Feedback Score: 7 reviews
Your injector spool valves sound like they are failing. Mine did all the same things and when I just put new injectors in it stopped.
