High EGT - Ford Powerstroke Diesel Forum
Old 10-10-2007, 01:15 PM
High EGT
I am a newbie so have a ? I have 04 f250 with 6in lift with 35's areo turbine exhaust cat delete stock tube. a super chip flashpaq and seems like i am getting hot egt, 700-800 at 55mph and if i get into it right to 13-1400 is this normal or running hot or bad probe, i have western diesel gauges. thanks for any help with this
frankie
Old 10-10-2007, 01:18 PM
Thats Mr. Oil Leak.....
7-800 at cruising speeds is pretty normal. with 35's if you are still running stock 3.73 gears it will run a little warmer. for the 13-1400 it doesnt take long for these things to get hot.. be sure to keep it under 1250. you can run 13-1400 but only for short bursts.
Also to the org!!
Old 10-10-2007, 01:19 PM
where is your pyro installed?
Old 10-10-2007, 01:26 PM
at the end of the line before turbo on driver side manafold
Old 10-10-2007, 01:29 PM
I'm pretty sure thats the right place -- Just know that sometimes people have them mounted in a different place, therefore the numbers are off some... but looks like MrJW got ya fixed up...
if you want to lower them though, think about doing the Zoodad (cut a hole in the rad/intercooler support to allow air directly into the intake), getting a bigger down pipe, and water injection... all will lower EGT's
Old 10-10-2007, 01:35 PM
thanks all, i have done the zoodad, did not cut big hole just a bunch of small holes. If i go with a bigger down pipe then will i need to get bigger muff, or just bigger down pipe and keep 3.5 exhaust? or is that a stuppid ?
Old 10-10-2007, 02:07 PM
check out farmboy diesel or another vendor they can hook it up for a fair price
Old 10-10-2007, 02:08 PM
Yah, if you were goign to get a bigger DP -- it'd be worth just getting the whole exhaust -- specially when FBD is selling a stainless exhaust 4" turbo back for $345!!!!! (plus shipping of course )
Old 10-10-2007, 02:12 PM
kool, just spent $220 for my exhaust and cat delete.live and learn
