Exhaust Pressure Sensor - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-17-2012, 09:32 AM Thread Starter
I have a bone stock 2004 F-250 with a 6.0L Powerstroke. We use it to tow a fifth wheel travel trailer. I have a check engine light that popped up a few days ago. It gives an error code of P0470 Exhaust Pressure Sensor A circuit. I had my EGR valve replaced last year and recently had a bad injector replaced.
Could someone please give some help with this code and some possible fixes?
Thank you,
ka4bni is offline
post #2 of 4 Old 07-17-2012, 01:02 PM
Quoted: 2 Post(s)
First thing i would do is take off your EBP sensor and the tube connecting it to the manifold and clean it. It could be plugged with soot. Its on the drivers side front of the manifold and the sensor is probably bolted to the thermostat housing.
2006 F350
6.4 banjos
FP spring
Insight CTS
IDP/Looney SCT X3
Studded
Durastroked
S&B,CCV
FICM Repair/PHP 40hp
2008 F250 FX4
DPF-R +
06DZL is offline
post #3 of 4 Old 07-19-2012, 12:30 AM
possible fixes include what 06DZL mentioned and if that doesnt fix it look at the ebp sensor or connector itself to be the issue good luck
Ford Senior Master Tech
2006 CCSB 6.0 Modified
dieselnate6.0 is offline
post #4 of 4 Old 07-20-2012, 03:13 PM
scha0786's Avatar
Quoted: 19 Post(s)
clean tube had same thing happen to me
04' F-250 6.0L
AFE Stage 2 intake
Liberator EGR delete kit
4" MBRP Turbo back (straight piped) WHISTLE
Quad Piller Gauge
zoodad mod
Nitto Dura Grapplers
Edge Insight CS
DieselSite Coolant Filtration
Upgraded fuel pressure spring kit
upgraded turbo oil supply tube(solid)
upgraded turbo drain tube
SWAMP's 48V FICM
Rotella ELC
Firestone Ride Rite air bags in rear
draw-tite 30k hide-a-goose kit
scha0786 is offline
