2003 6.0 Engine Wiring harness - Ford Powerstroke Diesel Forum
post #1 of 23 Old 06-22-2012, 08:48 AM Thread Starter
DEEJAY0380's Avatar
Okay turns out my 2003 6.0 engine wiring harness is obsolete and is no longer made by ford... does anyone know if i can use a 2004 harness but move the ICP sensor wire to the back by the IPR sensor?
does anyone know the part number for the different wiring harnesses? Also is there anyone that knows the part number for a ECM? my wiring harness shorted out my ECM
DEEJAY0380 is offline
post #2 of 23 Old 06-22-2012, 08:49 AM
Send a message via Skype™ to bwmtnbiker
Have your tried calling Tousley Ford? I find it hard to believe they would discontinue a wiring harness for such a popular product...
-Brian
2003 F-250 6.0L - Lariat King Ranch
-300k+ miles and still strong
Current Mods
-6.5" Pro-Comp lift
-Edge CTS
-SCT X3 (Tuned by Vivian
-4" Turbo Back Silverline Exhaust, 5"tip
-Blue Spring Mod
-Sinister Coolant Filter
-Oil Cooler
-Sinister EGR Delete
-OEM Cab Lights
Wants/Soon
-ARP Studs
-MTW Stage 1 or Hybrid
-6.4 Banjo Bolts?
bwmtnbiker is offline
post #3 of 23 Old 06-22-2012, 08:56 AM Thread Starter
DEEJAY0380's Avatar
you and me both i called the dealership that my division of ford get our parts from which is Peoria Ford of AZ. they still make the 2004-2007 wiring harnesses but since the 2003 was the last year they made that harness since they switched the HPOP's up where the ICP and the IPR sensors are in the back where 2004 move the ICP sensor to the LS valve cover
post #4 of 23 Old 06-22-2012, 09:10 AM Thread Starter
DEEJAY0380's Avatar
called Tousley Ford and turns out they discontinued the 2004 main harness as well, i've been replacing all the parts that can fail on this thing with new parts so i don't have run-ability issues but looks like i'm stuck trying to fix my fried harness
post #5 of 23 Old 06-22-2012, 09:13 AM
Man that really blows... Well i hope you can figure something out... maybe adapt a newer harness in and just splice new wires to run to the icp?
-Brian
Current Mods
-6.5" Pro-Comp lift
-Edge CTS
-Blue Spring Mod
-Oil Cooler
-OEM Cab Lights
Wants/Soon
-ARP Studs
-6.4 Banjo Bolts?
post #6 of 23 Old 06-22-2012, 09:15 AM Thread Starter
DEEJAY0380's Avatar
yeah that's what i'm going to have to work with since ford doesn't sell the 04 harness no more looks like i'm going to have to junk yard it.
thanks for lookin into this post..
post #7 of 23 Old 06-22-2012, 09:21 AM
Junk yard is probably going to be your best bet. Makes me worry a bit cause i too have an 03.
Best of luck to ya and I may have to see if I can find any round here.
-Brian
Current Mods
-6.5" Pro-Comp lift
-Edge CTS
-Blue Spring Mod
-Oil Cooler
-OEM Cab Lights
Wants/Soon
-ARP Studs
-6.4 Banjo Bolts?
post #8 of 23 Old 06-22-2012, 09:22 AM
BRAND NEW OEM MAIN ENGINE WIRING HARNESS FORD #5C3Z-12B637-BA | eBay
Maybe
http://www.ebay.com/itm/FORD-04-07-F...#ht_500wt_1413
-Brian
Current Mods
-6.5" Pro-Comp lift
-Edge CTS
-Blue Spring Mod
-Oil Cooler
-OEM Cab Lights
Wants/Soon
-ARP Studs
-6.4 Banjo Bolts?
post #9 of 23 Old 06-22-2012, 09:30 AM Thread Starter
DEEJAY0380's Avatar
thanks god knows i need it that's alot of wires to stare at.. do you know if it makes a difference if i run a ECM from a vehicle that has 4wd cause mine is a base xlt 2wd no bells and whistles here except the turbo LOL
post #10 of 23 Old 06-22-2012, 09:33 AM Thread Starter
DEEJAY0380's Avatar
our harness would start with 3C3Z- but i don't know the rest. i spoke with a Tech here he said don't use a harness that newer than 2004 or that has dual alts so now we know..
