05 6.0 Running Rough/Blue Smoke - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-04-2012, 06:33 PM Thread Starter
Hey everyone, first of all I'm new to diesels and powerstrokes so bare with me.
I just recently purchased an 05 F350 and upon startup the vehicle starts and runs with no problems at idle until I start moving. After the truck shifts into second it seems to start hesitating and running rough and i notice a bluish tint smoke come out of the tailpipe. The truck will run rough and smoke a bit until it reaches operating temperature then the problem completely disappears. It only happens on cold starts and until I reach operating temperature. Anyone have any ideas on what to start looking at so i can resolve this issue?The truck is completely stock with no mods. Any help is appreciated
Thanks,
Tom
2005 F-350 Lariat Supercrew 6.0 Powerstroke
TmoGTO is offline
post #2 of 6 Old 06-05-2012, 03:03 PM
x148's Avatar
Injector o rings
x148 is offline
post #3 of 6 Old 06-06-2012, 11:12 PM Thread Starter
Ill have to look into that, but was wondering if a bad FICM or Injector stiction could also be the cause of my issue?
TmoGTO is offline
post #4 of 6 Old 06-07-2012, 06:55 AM
x148's Avatar
also possible, throw some fuel treatment in the tank when you fill it up
05 F350
-Sinister EGR Delete
-Banks High Ram
-Blue Spring
-Air Dog II
-K&N Intake
-H&S Mini Max
-Swamps 58v FICM
-03 Turbo
-5" MBRP turbo back
-ARP Head Studs
-Cat ELC1 Coolant
-6" Lift on 37" Toyo M/T
-Detriot True-Trac with 4.56 Gears
-Pro Comp Trac Bars
x148 is offline
post #5 of 6 Old 06-09-2012, 09:49 AM
My 04 is doing exactly the same thing. Anyone solved this problem before?
csamus is offline
post #6 of 6 Old 06-09-2012, 12:26 PM Thread Starter
Went ahead and bought some Motorcraft Cetane Booster and so far the truck has been pretty responsive to it and have not really had much of an issue. Im going to try an oil change to a full synthetic 5w-30 and rev- x and see if that helps at all as well.
TmoGTO is offline
