Need help, ac/heater fan stuck in defrost - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-17-2012, 07:33 PM Thread Starter
Jteets75's Avatar
Exclamation Need help, ac/heater fan stuck in defrost
Like i said in the title no matter what setting i put the direction in all it does is blows out of the defroster, any idea what is causeing this? i just bought the truck for an auction so i have no idea how long it was been doing it
Jteets75 is offline
post #2 of 10 Old 04-17-2012, 07:37 PM
cweiss87's Avatar
Could be the switch or the blend door. Can you hear it try to switch
Sent from my SGH-T759
04
F-250 FX4.
Sct X2 with tunes from Gearhead
Zoodad mod
High idle mod
Straight pipe exhaust
BDS leveling kit
Stage 1 intake
cweiss87 is offline
post #3 of 10 Old 04-17-2012, 07:42 PM Thread Starter
Jteets75's Avatar
No not a sound
Sent from my IPhone while "working"
Jteets75 is offline
post #4 of 10 Old 04-17-2012, 07:43 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Vacuum loss.
You have 4wd? If so, check the lines to the hubs.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 10 Old 04-17-2012, 07:47 PM Thread Starter
Jteets75's Avatar
Originally Posted by jesilvas View Post
Vacuum loss.
Ya it is, I'll check in the morning thanks! Will I see a crack in the line or one might have poped off?
Jteets75 is offline
post #6 of 10 Old 04-17-2012, 07:50 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Both maybe.
You can plug off individual lines and see which one plugged makes the defrost change.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 10 Old 04-17-2012, 07:52 PM Thread Starter
Jteets75's Avatar
Ate they easy to find?
Jteets75 is offline
post #8 of 10 Old 04-17-2012, 08:34 PM
cweiss87's Avatar
Hub lines usually only affect it when you engage the 4wd. Theres no vaccum goin to them until its engaged
04
F-250 FX4.
Zoodad mod
High idle mod
BDS leveling kit
Stage 1 intake
cweiss87 is offline
post #9 of 10 Old 04-18-2012, 01:46 AM
Hey I bet it's your vacuum pump itself. Turn the key on you should hear your pump running. If not it's the pump.
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #10 of 10 Old 04-18-2012, 06:37 PM Thread Starter
Jteets75's Avatar
Found out its the pump, she is as dead as a door nail, what are my options? Lol
Jteets75 is offline
