What should the PSI in the degas bottle be? - Ford Powerstroke Diesel Forum
Old 04-16-2012, 06:59 AM
What should the PSI be in the degas bottle of a 6.0 with new Head Gaskets and oil cooler?
At Ideal:
Normal HWY:
Under load towing:
Old 04-16-2012, 07:10 AM
Feedback Score: 5 reviews
No more than 16 PSI
Old 04-16-2012, 07:14 AM
I think 14psi is normal though..
16 psi she's blowing fluids ! what should they maintain under normal operations
Old 04-17-2012, 11:45 AM
14psi or less ..
Old 04-17-2012, 06:27 PM
It says on the cap usually.
Old 04-18-2012, 12:37 PM
I was always told it shuld operate and no more than 10 psi unloaded. I'm running a constant 16-18 under normal driving situations... No puking or coolant loss tho.
Old 04-18-2012, 01:07 PM
Make sure the degas bottle is not overfilled... The MIN line if the FULL hot.
Old 04-18-2012, 05:39 PM
I read your story and im sure you have bad HGs just like my trk did with your same symptoms. Its just your gaskets are not that bad yet.. I would almost bet money on it. 16-18 constant means problems..
