getting the EGR valve out - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-15-2012, 12:48 PM Thread Starter
DieselDweller's Avatar
I can get it to rotate in place, but I can't get it to pull out. Any tips?
I'm hoping to clean it and reuse it, so I want to be careful not to break it when I pull it out.
Thanks-
06 E-350 with 6.0
Quigley 4x4
Sportsmobile
Swamps hot FICM
IDP Street Tune
Updated FPR spring
About to have a new oil cooler and Sinister upgraded EGR Cooler - remind me to get back to work and quit surfing the web!
DieselDweller is offline
post #2 of 11 Old 04-15-2012, 01:02 PM
streetglider's Avatar
use a pry bar and gently lift around the edges it will pop out
streetglider is offline
post #3 of 11 Old 04-15-2012, 01:04 PM Thread Starter
I'll give it a try. It's pretty hard to get to most of the edges - things are tight under the hood of an E-350 with a 6.0 crammed in there,
06 E-350 with 6.0
Quigley 4x4
Sportsmobile
Swamps hot FICM
IDP Street Tune
Updated FPR spring
post #4 of 11 Old 04-15-2012, 01:06 PM
ZMANN's Avatar
Quoted: 1911 Post(s)
I bent a long screwdriver at the last few inches to get under the edges
ZMANN is online now
post #5 of 11 Old 04-15-2012, 01:14 PM
I also alternate spraying wd40 and carb cleaner on it to loosen up the crud as I am comeing up.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #6 of 11 Old 04-15-2012, 01:17 PM Thread Starter
Thanks guys - got it!
I just needed a bigger screwdriver that didn't flex as much as I pried it.
Now to clean the valve out - it's as coked up as an 80s hair band.
06 E-350 with 6.0
Quigley 4x4
Sportsmobile
Swamps hot FICM
IDP Street Tune
Updated FPR spring
post #7 of 11 Old 04-15-2012, 02:20 PM
Since it is so coked up what does the inside the intake look like. It may be woth the touble to pull the intake and have it vatted. You also may want to look at the ccv filter and clean that as well. Caution do not use solvent on they o-rings they swell up and distort and can't be reused.
post #8 of 11 Old 04-15-2012, 02:40 PM
HaysKSFirefighter's Avatar
Just a tip for anyone else, prying can bend the valve and damage it. I rotate it to where the holes are offset and I can get a long piece of baling wire through them. Secure each end of a 3' piece in the ears of the valve, the "U" part that is left over will give you enough room to smack it up a few times with a good hammer. Just make sure you hit it straight.
Tornado Alley PowerStrokers Director
2007 F-350 CCLB XLT FX4 ZF6 08 Mirrors, CTS, Gearhead, BD EGR Delete, Coolant filter, B&W, Custom rear springs, still rockin the stock head bolts and clutch!
HaysKSFirefighter is offline
post #9 of 11 Old 04-20-2012, 03:20 PM
ZMANN's Avatar
those EGR Orings should be removed and replaced IMOH and where is the CCV filter ?
ZMANN is online now
post #10 of 11 Old 04-20-2012, 04:02 PM
Suzuki6mx's Avatar
taking the intake elbow off helps alot too. More room to get hands or a tool on it. I just took mine out with a crows foot prybar. Make sure the clamps are tight on the intake or itll blow once turbo builds
2002 F350 ext cab SRW 6 1/2' bed(mine)
2008 F350 CC DRW 8' bed(Dads)
2012 Reg Cab DRW Dump
1996 Reg Cab DRW Dump
1999 Reg Cab DRW Dump (After a year of sitting its back and running good)
2003 Ext Cab DRW 8' Utilty
Suzuki6mx is offline
