contribution test numbers - Ford Powerstroke Diesel Forum
Old 04-12-2012, 08:52 AM
Feedback Score: -1 reviews
my truck has been having an issue for a little while now, if the truck is warm it always is pefect at cold the truck will shutter and run like sh**. i originally thought maybe it was ficm but could be wrong. i drove it cold to my buddies shop. as soon as we plugged it in to do contribution test cylinder 2 was slowly dropping to - 20 then to -40. by the time we noticed it truck zeroed out. all were at zero at idle. alot of them were dropping under throttle tho. any ideas? what should i be seeing for numbers.? do i need 8 injectors? thanks
Old 04-12-2012, 04:26 PM
To the top
Sent from my SCH-I510 using AutoGuide.com App
Old 04-12-2012, 04:38 PM
im having the same problem
Old 04-12-2012, 05:13 PM
Powerstroke Techie
Feedback Score: 3 reviews
You're never going to have a flat contribution under throttle. usually only at idle or light throttle do the RPM drops really tell you anything.
You may catch a heavy dead misfire under throttle but that's about it. If you're not feeling the miss it's probably not there.
Old 04-12-2012, 05:24 PM
Im def feeling the miss just don't know what to do with the scan tool to see what is dropping out. I initialy was thinking ficm but starting to think injector
Old 04-12-2012, 05:41 PM
Powerstroke Techie
what kind of scan tool were you using?
Old 04-12-2012, 05:43 PM
This is what I do: I let the truck sit over night, the plug in the scan tool( snap-on) then set up the contribution test, then start the truck and which every cylinder or cylinders can't 0 out those are the ones. But torn high presure o-rings can cause funky problems.
Sent from my DROIDX using AutoGuide.Com Free App
Old 04-12-2012, 05:44 PM
I want to say snap on motus ? it was showing numbers with truck running. All were zero at idle for most part. One was bouncing around for about a minute. By then truck was almost warmed up
Old 04-15-2012, 03:50 PM
sounds like stiction and even the dealer couldn't figure mine out with a scan until a second injector had an issue
I don't see how you could drive it cold to the scan location and get a good test ?
like mentioned they need to really be cold
Old 04-22-2012, 05:16 PM
Did a cold contribution test today. Cylinder 4 was pretty much dead till warm. Others were all over the place too till warmed up? think i need an injector and ficm?
Tags
contribution, ficm, injectors
