Long trip with lots of problems... HELP! - Ford Powerstroke Diesel Forum
Old 04-05-2012, 02:10 PM
Alright - I will try to make this as short and concise as possible. I have a 2003 6.0 with 200,000 on the original gasket and studs as far as I know. Until last weekend I have had my share of problems but now I'm scared. Last weekend I had to make a road trip of roughly 2000 miles round trip on a fairly fresh oil change, with fuel filter changes (all ford parts) with Rev-x 8oz added to oil...
I have the Edge Insight CS and about 1/4 of the way through my trip I started noticing that my FICM voltage was beginning to intermittently drop below 45.5 volts at random. Sometimes it would even get in the 42 volt range. I had now option to turn back as I was on my way to attend my grandfathers funeral. Upon my arrival I noticed that the truck would spit, sputter, and surge a bit at the red lights with no noticeable drop in performance otherwise. I averaged 22mpg round trip with plenty of power to spare on the road so I didn't really think much of it. The next morning upon a colder then normal start up the FICM voltage was in the 38volt range for a few minutes and the truck was still missing and surging. I checked the codes and found the injector 5 contribution code. Thinking that may be the result of a bad FICM I cleared it and continued on... Even when the FICM is running at 48volts the truck is still missing and surging. What could be going on? Coming home yesterday my truck was running great through the mountains when my EDGE Insight CS took a crap and left me driving blind...
Anyway - now I have a rough running truck with what feels like a misfiring injector and a bad FICM... My question is when I repair the FICM do you think it will clear up the stumbling, missing, and surging? I currently don't have any injector codes. Should I upgrade to a 58volt FICM???? Could anything else be causing this?
Old 04-05-2012, 05:17 PM
What was your battery voltage doing during all of this?
Old 04-05-2012, 05:49 PM
Batt voltage fluctuates between 14.1 & 14.4 normally with everything running. Had a new alternator installed last year.
Old 04-05-2012, 06:24 PM
I was just wondering since that could mess with the FICM voltage. Since your FICM voltage is low it would seem to me like that is the culprit. I would fix that first and see if that does the trick. I personally haven't had FICM issues but I'm sure someone will chime in that has.
Old 04-05-2012, 08:21 PM
information regurgitator
Yep.
I currently don't have any injector codes. Should I upgrade to a 58volt FICM? Could anything else be causing this?
I went with the 48 volt repair through Ficmrepair.com. Ed got it all fixed right up and shipped off fast.
Check them out.
You don't want to continue driving the truck with a bad FICM any longer than you absolutely have to. The low voltage being delivered to the injectors can harm them.
Old 04-06-2012, 03:25 AM
Alright - sounds good. I will give them a try. I appreciate the assistance.
Tags
ficm, injector, missing, surging
