Intermitten power issue
Hi all,
I have searched the threads to try and narrow it down and may have a good idea what is wrong but at the price the part will cost I want to hear what you folks say and make sure I am on the right path. I have an early '04 PSD CC 4x4 and other than a custom tune, lift and 35" tires everything else is stock. Even full stock exhaust! The issue is that every once in a while the truck will idle a bit rough and clear up on its own. Sometimes after a full throttle run up a freeway entrance when I back out of it it has a lack of power but if I hold the pedal down it comes back to life after about 2 or 3 seconds. Until then it flat has no power and no odd noises. It seems to do this when it damned well pleases but I have noticed that it happens more often when the vehicle isn't up to full operating temp. Its not cold, just not completely warmed up. It did this both before the tune and after so I know its not a tuning issue. Any ideas? From my research I am coming up with a FICM issue, but at the price of a new one I hate to shell out that kind of coin to find out it didn't correct the issue. I wish there were a CEL so I could get the trouble code but there isn't. Thank you all in advance for the help! |
Does black smoke come out the exhaust during this time?
Sounds like Stuck EGR Valve. Clean it to test, replace if necessary. Takes 10 minutes ![]() Even better, delete the EGR system! =D |
No smoke of any kind comes out during the issue. Only smoke is the occasional puff at WOT after the tune but that is normal. I will however try to clean the EGR this weekend and see if that helps. I have plans to delete it but I have to save a bit first. I want to do the delete, coolant flush and oil cooler all at once. |
Had a similar issue a year or so ago. I would be cruising 60mph and when I went to accelerate, I had to push the skinny pedal to the floor for a few seconds before it would jump to life.
It did it on and off until my cooler ruptured. |
Oh man.... What cooler went? Was it the oil or EGR? I have plans to delete the EGR cooler soon but I am trying to build up the cash to flush the coolant and change the oil cooler at the same time. I may rush the EGR cooler now if that is the issue
Well I replaced the EGR cooler with a Sinister EGR delete kit and add Rev-X to a fresh oil change and there is no difference. I still get the same issue from time to time. Although now that weather is warming up here in CA it is getting more rare.
I think it has been traced to a failing FICM.
how many miles? also do you let it idle alot? My unisom ring was all caked up and the vanes couldn't retract fast enough so after accelerating and letting off as soon as i went back to hit the gas there would be a few second delay and then it would be fine. My truck had 108k and around 3500 hours when that happened.
Do you have the oem oil cap and motorcraft oil filter? Mine was surging and idling rough intermittently but throwing no codes... Turns out I had a napa oil cap and autozone oil filter... Changed them out for oem and it's like a whole new truck.. Better throttle response, more power, and no more rough running or surging.
When I removed the EGR cooler I was going to clean the turbo but it looked very clean in there already so I left it alone. It was apparent that the top end of this motor was pulled apart prior to my ownership so I am guessing they cleaned it up at that point. As for mileage it just turned 90,000 this last weekend |
