blue spring issue - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-29-2012, 06:17 PM Thread Starter
scparrish's Avatar
Quoted: 92 Post(s)
Feedback Score: 3 reviews
blue spring issue
alright I installed a blue spring on my truck never had any issues everything is tip top. I installed a blue spring on my dads truck and now it has a crazy whistling sound that takes place at idle and when you let out of the pedal whats the deal I feel bad because I don't live close enough to hop over and fix it but I don't really know whats wrong
White Early 2004 F250 Harley
Adrenaline hpop, Aeromotive, ARP, BPD, BTS, Carli, Fox, Fuelab, GH/TSD/Wildman, Holders 225/75, KC Turbo, PMF, S&B, Mishimoto rad/ic, 08 axle swap
scparrish is offline
post #2 of 12 Old 03-31-2012, 12:11 PM Thread Starter
scparrish's Avatar
Quoted: 92 Post(s)
anyone?
post #3 of 12 Old 04-01-2012, 05:54 PM Thread Starter
scparrish's Avatar
Quoted: 92 Post(s)
need some info talked to a tech i know maybe its not seated right anyone have input on that
post #4 of 12 Old 04-01-2012, 09:06 PM
DRILLROCK's Avatar
Well it could not be seated right, there is an indention for that spring in the cap with the screws, if its not seated in there it would make the spring tighter then it should be because it compressed a hair more than it should be. I don't think that would make it whistle thought, did you loosen the cold air return tube for easier install? That could be the source of the whistle if its loose, or the air intake system? I left mine loose after blue spring install and it blew off under WOT test run. Just a thought.
Jeff
2005 F-350 CCLB King Ranch 4 X 4
Airaid cold air intake box & filter
MBRP TURBO BACK 4" Exhaust
2 1/2" Rancho Coil Spring Front Level Kit
ReadyLift TractBar Relocation Mount
RanchHand Front Replacement Bumper
Ride Rite Rear Air Bags
ScanGauge ll
Dieselsites coolant filter
35/12.50/18" 10p Toyo open Country ll
RC Dual Steering Stabilizers
Atlas 40 from Ficmrepair
River City Diesel EGR Delete
Other Rides--06 Ford Expedition limited--96 Jeep Cherokee--08 GMC crew cab
DRILLROCK is offline
post #5 of 12 Old 04-01-2012, 11:05 PM
Check the fuel line you disconnected, check filter cap, check housing torx screws and housing gasket? Did you make sure all the boots and clamps are all tight?
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #6 of 12 Old 04-02-2012, 03:43 AM
Gunny_990's Avatar
Whistling means something is leaking, as mentioned you need to go back over everything to ensure it is properly seated. Hope you find the problem, good luck.
Charlie
Gunny_990 is offline
post #7 of 12 Old 04-02-2012, 06:34 PM
ryan.sampson's Avatar
1. check for any fluid leaks, that would be a dead giveaway you didn't put something in right
2. sounds like an intake leak or something like drillrock said. did you have to take anything else apart, loosen anything, or might have accidentally bumped something hard enough to create an air leak??
2002 F150 4.6L AUTO RCSB
SOLD:2004 F250 CCSB SRW 6.0 PSD AUTO
EGR Delete Kit / Livewire and EGT
Hercules FICM / ID Extreme / Vivian's Looney / Spartan Hybrid Race
A-Pillar 3 Gauge Pod w/ Fuel Pressure, Boost, Trans Temp
4" Turbo Back Straight Pipe / Blue Spring / 6.4 Banjos
7" Pro Comp Lift and Leveling / Zone Adj. Track Bar
36/15.50 Baja Claws on 20" Rockstars
13.882 @ 95.25 mph running 285 AT's
**Friends Don't Let Friends Drive Stock**
ryan.sampson is offline
post #8 of 12 Old 04-02-2012, 06:43 PM Thread Starter
scparrish's Avatar
Quoted: 92 Post(s)
for sure not the intake there are zero leaking fluids I have heard leaking turbo piping this is not that this is a weird deal this isn't my first time to take this crap apart and put it back together it's making me crazy custom fuel system ftw lol
post #9 of 12 Old 04-02-2012, 06:56 PM
the whistling is only at idle? as soon as you touch the gas its gone? if so i doubt its the turbo piping, it would get worse right?
post #10 of 12 Old 04-02-2012, 06:59 PM Thread Starter
scparrish's Avatar
Quoted: 92 Post(s)
yep it comes back when you let off the throttle not exhaust/intake
