No power after 45-50 MPH after work done - Ford Powerstroke Diesel Forum
Old 03-27-2012, 01:23 PM
Hey guys, im new to the Powerstroke world.
i just ha my Cat deleted and egr went out and had that deleted. now there is no power after 45-50 on the highway, unless i floor it for a few secs, then it will shoot up RPMs. also, since the Cat/Egr delete, it does not smoke... i used to be able to blow puffs at tailgaters lol
No trouble codes besides the EGR.... i changed the fuel filter, its due for an oil change soon, i just dont know what it could be.
i was thinking (but i know very little about these engines):
*Fuel pressure regulator (has silver spring that i know of, want to get the new blue spring anyways)
*Computers reflashed
Any help would be great!!!
i have on my truck:
*MBPR 4" cool dual turbo back exhaust W/ no cat
*Edge juice W/ attitude
*egr delete
*brute force intake
Old 03-28-2012, 08:34 AM
Edit:
So i was digging around in the enging bay last night, found a broken ground wire. gonna fix it and see it its any different.
Again, ANY help would be great!!
Old 03-29-2012, 11:04 AM
Same problems
After I installed a delete kit and new oil cooler and FICM i have the same problems. I was thinking the replacing the pedal (TPS). But Im not a mechanic and will try any tips to fix this problem.
Old 03-29-2012, 11:12 AM
any codes? and you may want to look around the ficm and make sure the connectors are in all the way/ the harness isnt chaffed. i found a broken off ground wire coming out of the ficm harness.... i am new to diesel trucks and am in no way a mechanic lol but can handel simple things.
also, my truck will build boost, but stays around 2K rpm and does not "go"....
Old 04-05-2012, 02:06 PM
Think i have it figured out.
just took it to the shop, they hooked up a scanner. turns out my turbos bad Going to see how my tax refund looks and plan to put in a powermax... for $1400.... hope thats all the problems i have for a while.
Tags
power loss egr flash
