05 F350 6.0 Coolant leaking on ground - Ford Powerstroke Diesel Forum
Old 03-24-2012, 10:35 AM
Just did a coolant flush on my 6.0 and today after driving I notice coolant leaking off the bottom pulley. To this point everything is stock. The head gaskets were replaced 2 years ago. Prior to flushing I had to often add coolant especially when towing. Not showing up in the exhaust but believe it may be getting boiled out in the egr cooler. Will bad EGR cooler show up on the ground? Water pump?
Thanks!!! Bryant
Old 03-25-2012, 07:30 AM
Really could use some advice on this one. thanks!!!
Old 04-01-2012, 09:38 PM
id guess water pump
Old 04-02-2012, 01:40 PM
Could be a number of things. Bad pump; hose; loose clamps; bad freeze plug; leaking gaskets etc
Old 04-02-2012, 02:10 PM
Mine was losing coolant also; leaking on the ground. Turned out it was a weld on the EGR Cooler assembly. I deleted it. Problem gone.
Old 04-02-2012, 02:46 PM
My coolant leak turned out to be the degas bottle itself. Replaced and gone.
Sent from my DroidX using Autoguide
