04 won't start please help - Ford Powerstroke Diesel Forum
Old 03-15-2012, 01:18 PM
Hi I have a 04 250 auto all stock with 134000 miles on it. It has never gave me any trouble always ran good but this morning I got in it to start it and all it does is crack will not hit or noting what do u think it is and or where should I look to try and fix the problem. I thought it was the fuel pump but after speaking to a few people they think it is either the computer or the oil pressure pump does anybody agree? Thanks in advance any help would be appreciated
Old 03-15-2012, 04:38 PM
Do yoy have anyway of checking for codes or monitoring pcm data?
Old 03-15-2012, 04:45 PM
No I don't I had it check engine light on a few weeks ago and it was code p404 I think was the only code it was egr and I cleaned it and the light went off I know by reading there could be more codes but I have no way of reading it do u have any suggestions and ps thanks for writing me back
Old 03-15-2012, 04:50 PM
Does it smoke or try to start at all when cranking? Does it have strong crank? Does the oil pressure guage on dash come up when cramming?
Old 03-15-2012, 04:54 PM
Crank strong doesn't even try to hit and no smoke and I didn't notice the oil pressure when cranking it I can go and try if u need me to
Old 03-15-2012, 04:55 PM
You really need to take it some where and have it scanned for codes and a live data scan run. It can be a FICM problem, wireing, low pressure oil problems Highpressure oil problems lack of fuel. At this point we are just makeing educated guesses.
Old 03-15-2012, 05:03 PM
If it is a late 04 unplug
the icp sensor and see if there is oil in the connector and if it will start with it unplugged... If so then your ICP is bad... Everything else it could be I think you will need to see some live data or actually test some components... Ficm can be checked pretty easy by yourself also if you have a multimeter... Just do a search for ficm test procedures. Oh and if it is a late model 04 the ICP is on the passenger side front of the valve cover... If it's an early 04 then the sensor is under the turbo and a royal pain to get to
Old 03-15-2012, 05:28 PM
I will have to check to see if it is early or late model it is a Harley edition if that helps I will have to get it scan to see I was going to check the fuses for the fuel pump I was told to spray just a little bit of starting fluid in the air box while cranking to see if it hits or not I know that it is a risk to that but little may help me troubleshoot it I will check on that sensor in the morning thanks for all the help and keep them coming I could use it thanks
Old 03-16-2012, 10:09 PM
Ok tonight I went out and check the fuses and they were all good I checked them all and push them and then check under the hood and I looked around after all the fuses and relays were good I just turn it on to check the fuel pump to see if I hear it and I did hear And I wanted to crack it to see the oil pressure while cracking and it fired right up so I have no clue on where to look now any ideas?
Old 03-16-2012, 10:32 PM
does it smoke or rattle bad when it starts? can be the ficm going bad you can find instructions here on how to check the voltage on it and tell if its good or bad, hope you resolve it soon cuz i hate it when my powerstroke is sick :/
Sent from my SAMSUNG-SGH-I997 using AutoGuide.com App
