Squirrel chewed vacuum lines
2005 F250, 6.0
That's right. Cleaned out a nice sized nest yesterday. After I found that the A/C wasn't working I looked closed, noticed she'd chewed ALL the vacuum lines where they attach to the pump. She also cut the wires that go to the accumulator or dryer, whatever that silver canister is on passenger side of the engine bay, towards the rear. What I need is a diagram of those vacuum lines as I have no idea which ones go where. One of them I can tell because she left most of the line, but the others are have long sections missing. Guess she ate them? Stupid squirrel. Anyway, any help with a diagram or a nice detailed picture of the pump and where the lines run to would be a huge help. Thanks. |
Bad squirrel...no nuts
![]() Sorry man IDK but here is a
Yeah. no nuts, lol.
Thanks. |
I've got the A/C working again but i can't figure out how to get vacuum to the hubs... There are two lines coming out of the controller, one goes to the hubs I'm guessing but I don't know what to do with the other. |
Got everything working but the 4WD...
If anyone has a picture of the red vacuum line that comes out of the hub lock controller thing, that would be much appreciated. |
This is what the solenoid looks like. I have manual hubs and cant get you an actual picture.
I don't have a complete diagram, but I supect the solenoid is plumbed between the hublock vacuum reservoir and the hubs themselves. Just a guess... MikeB Pulse Vacuum Hublock (PVH) Solenoid Removal and Installation Disconnect the pulse vacuum hublock (PVH) solenoid. Disconnect the harness connector. Remove the vacuum hose connector. ![]() Remove the bolts and the PVH solenoid. To install, reverse the removal procedure. |
Thanks though! |
Just noticed the f-er also cut my GD IAT sensor pigtail.
Arrgghhh!!! ![]()
Makes you want to go squirrel hunting.
