UPDATE TO MY DRAMA!!! - Ford Powerstroke Diesel Forum
post #1 of 19 Old 03-12-2012, 11:01 AM Thread Starter
Shotgun_girl's Avatar
I also posted this on my orginal thread "do the problems ever end". I need some input from you diesel geniuses!!
Just got a diagnosis!! Ya'll tell me what you think cause I don't believe it!!! John tells me that Ford/Oasis is telling him he needs to replace ALL 8 INJECTORS! WTF??!!
I don't think John really is buying into either but I think he is out of ideas. They told him that one of the injectors probably shorted out and fried all of the other injectors. He told them that it failed me while driving and just quit. They said it was probably because the engine got to hot. I watch my gauges like a hawk and my pyrometer and other temp gauges were completely normal!!! He told them that too. I'm sure they just think I'm just some dumb broad that doesn't know her left from her right. I think Ford/Oasis is telling John to basically start throwing parts at it!
EVEN if they are by chance correct and all 8 injectors are fried...WTF caused it?!! What's to say that I put $2k worth of injectors on it and this doesn't happen again in 4 months?? IF the engine did get too hot (which it didn't) what caused it?!
So basically they are saying that a truck that has had ZERO starting (haven't had to plug it in once this winter!) or running issues other than having the IRP valve replaced 5 days earlier suddenly FRIES ALL 8 INJECTORS in an instant driving down a GRAVEL road at 25 miles per hour.
PLEASE WEIGH IN ON THIS!! Justin Mix is going to talk to my mechanic (thank you Justin ) to find out some more info using vocabulary that goes way over my head.
Nikki
It spends a lot of time on the rollback
2004 6.0 F350 FX
Straight pipe
AFE cold-air intake
Sinister EGR delete
SCT tuned
Dieselsite coolant filter
Blue spring
6.4 Banjo Bolts
Things replaced:junk gold coolant
two injectors
2 alternators
oil cooler
2 FICM (one replaced before I purchased)
some little transmission part (easy $16 fix)
IRP valve & HPOP
gasket on turbo
degas cap (easy fix $4)
no doubt there will be more to come...it is a 6.0
Shotgun_girl is offline
post #2 of 19 Old 03-12-2012, 11:18 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
What failed on the IPR?
has anyone bothered to test FICM voltage?
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 19 Old 03-12-2012, 11:28 AM
Quoted: 357 Post(s)
Feedback Score: 5 reviews
Here is a link to the other thread if you guys want to see what has or hasn't been checked yet...
Do the problems ever end??!! ARRGGG!
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #4 of 19 Old 03-12-2012, 11:42 AM
I would suspect more of a wieing harness failure causeing all 8 to show bad all at one time, assumeing they are bad. Now Ford does recomend changeing them all when several injector go out at once. This is due to history has shown that when several fail the rest useually follow soon after. Besides it sells parts.
I am afraid it is now time to break out the manual and flow charts and do some serious testing and verification. Regretably not all techs are the same even Fords techs.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #5 of 19 Old 03-12-2012, 11:45 AM Thread Starter
There are ZERO codes showing. The only two codes that show up are my two normal egr codes from my delete and they are always there.
Nikki
2004 6.0 F350 FX
Straight pipe
AFE cold-air intake
Sinister EGR delete
SCT tuned
Blue spring
6.4 Banjo Bolts
two injectors
2 alternators
oil cooler
IRP valve & HPOP
gasket on turbo
post #6 of 19 Old 03-12-2012, 06:56 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
the ford technical hotline is completely hit or miss. I usually have to go back and forth for a day or so before someone finally calls me with some legitimate ideas. unfortunately it sounds to me like the injectors are a shot in the dark, a costly one at that
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #7 of 19 Old 03-12-2012, 07:55 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
Unfortunately more misses than hits, more than I care to admit from my experience.
And a "shot" that I wouldn't be comfortable making on the customer's dime. If this were a warranty repair, on the other hand .....
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #8 of 19 Old 03-12-2012, 08:27 PM Thread Starter
It's nice to hear someone say that!! If the FCIM switch doesn't do anything tomorrow, I won't know what to do. I just don't think it's the injectors.
Nikki
2004 6.0 F350 FX
Straight pipe
AFE cold-air intake
Sinister EGR delete
SCT tuned
Blue spring
6.4 Banjo Bolts
two injectors
2 alternators
oil cooler
IRP valve & HPOP
gasket on turbo
post #9 of 19 Old 03-12-2012, 08:37 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
Neither do I. And in fairness to the tech that's working on your truck, I don't think even HE thinks it's the injectors either.
m-chan68 is offline
post #10 of 19 Old 03-12-2012, 08:44 PM Thread Starter
M-chan don't you ever get tired of all of the sad-*** 6.0 owners screamin' for you help?? LOL
Nikki
2004 6.0 F350 FX
Straight pipe
AFE cold-air intake
Sinister EGR delete
SCT tuned
Blue spring
6.4 Banjo Bolts
two injectors
2 alternators
oil cooler
IRP valve & HPOP
gasket on turbo
