laundry list of problems - Ford Powerstroke Diesel Forum
Old 03-10-2012, 03:00 PM
well to start off i had surging problems when at a stop light. so if i was at a stop the truck would want to lunge forward. but i got no check engine or codes on my tuner ( edge juice platinum) so i let it go for a little bit and then it stopped.
but then about 6 months later when i would go to accelerate with a heavy foot the engine would bog down or skip or miss. i did get a code po335 and po336. that lead to camshaft sensor and performance. i rad on here and everyone said to change it, so i did and the problem continued. so i took it to to the ford dealership and she returned aith a laundry list of stuff includung that now they can't get my truck to continue running but when i dropped it off it ran.
Blown EGR cooler
restricted oil cooler
bad ficm
and no related center section of my turbo was dirty and needed to be cleaned or replaced
estimate of $6000. i ran out of time and need my truck to i went through with it and the delaership assured me after this there will be no problems whatsoever
and that it will be like a new truck. also a 12 month 12000 mile warrenty on work.
here are my questions
are all these problems related?
is that a good price?
are they over looking anything?
why did my tuner not catch this?
should i switch tuners?
here is my info
06 f350 lariet 4x4
88000 miles
edge juice platinum
straight exchaust no cat or muffler
thanks in advance
Old 03-10-2012, 03:32 PM
Powerstroke Techie
Feedback Score: 8 reviews
Well to start off the clogged oil cooler took out the egr cooler. The turbos unicen ring most likely is stuck. The ficm is dropping voltage from bad solder on the dale chips. As for the rice well you could shop around.My question to you is this where you useing coolant and how many miles is on it? if its over 100k and head gaskets have never been done i would do the works! bullet proof it now. if it where me i would take it home and stud it with ford headgaskets as all black onix ive seen done failed and ive seen alot. then i would do external oil cooler, egr delete and replace t fitting with solid tube. also replace both dummy plugs and NO MORE PROBLEMS EVER. dont forget to split turbo and polish unicen ring track on both sides. if the vanes tabs that ride in ring are worn flat they are bad. hope this helps you. ohh do it yourself there is no better learning experience!
Old 03-10-2012, 06:07 PM
Forgot to mention
I forgot to mention that that quote was also replacing a is head gasket. And I was loosing coolant also for the last 2 months. I already gave them the go ahead to do the work and they said that the new eye cooler has been modified to fix the original problems the 6.0 had. It has 88000 miles and I do quite a bit of towing a 5th wheel
By the way I am actually in the navy now I am a AW aircrew/ rescue swimmer instructor
Old 03-11-2012, 08:47 AM
Powerstroke Techie
The price quoted above is a very good price for all the work listed, if it's done properly. I would throw in a set ARP head studs in there, along with an engine harness by the sounds of the two codes listed above. Installing an engine harness will eliminate any and all electrical circuit issues, since you're already in this deep.
Tags
6.o problems
