04 6.0 nightmare!!!!!!! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-09-2012, 03:59 PM Thread Starter
OK for starters everyone on here seems to know ALOT more about desiels than me which is great. Thanks in advance.
After reading through alot of the posts I seem to have some of the same problems and the others with a few exceptions.
2004 6.0l F250 4x4 screw 121000miles.
for starters 2 days ago while driving down the road at 65 the motor sputtered then shut down luckly I was able to get o the side of the road without incidant. Sat there for a few minutes and tried to crank but it would just turn over and over. let it sit for about 5 minutes then tried to crank finally got it started but she was idling REALLY rough smoothed out abit and I put her in gear stepped on the throttle and nothing happened. I pushed the pedal to the floor and it SLOOOOWLy started to move out and about 1mph incriments was able to get up to 45mph and limp home. T
Thought is was a fuel issue so I changed out both filters and pulled some fuel to check for water. No water so i was hoping it was fixed.
It cranked up but ran rough and would only stay running for about 30 seconds before it would shut off( Sounds like it is running out of fuel.
Pulled off the top fuel cap and have a massive amout of air bubbles filling up the housing( I did leave the filter in when I cked it).
But after talking to several mechanis and reading all the different posts it sund like it could be anything from an IPR or ICP sensor to a FICM or HPOP issue.
This is turnin out to be the worst ( and most expensive ) truck I have ever owned.
Last year I replaced most of the top with a new EGR cooler Oil Cooler head studs head gaskets injectors etc... and that was a chunk of change replaced at 107000 miles.
Any help is greatly appreciated
nvzblmn72 is offline
post #2 of 8 Old 03-09-2012, 05:25 PM
southend's Avatar
for starters....you need a monitor for the important PIDs..I have the edge CTS. It was my first purchase after reading the post on this sight. Bubbles in the fuel filter bowl could be combustion gasses passing the injector seals.....you need to check your fuel pressure and check the codes.
southend is offline
post #3 of 8 Old 03-09-2012, 06:23 PM
Shotgun_girl's Avatar
Welcome brother! It sucks...I'm on one week of mine being in the shop and still not knowing what it is. It doesn't get any better... lol
Nikki
It spends a lot of time on the rollback
2004 6.0 F350 FX
Straight pipe
AFE cold-air intake
Sinister EGR delete
SCT tuned
Dieselsite coolant filter
Blue spring
6.4 Banjo Bolts
Things replaced:junk gold coolant
two injectors
2 alternators
oil cooler
2 FICM (one replaced before I purchased)
some little transmission part (easy $16 fix)
IRP valve & HPOP
gasket on turbo
degas cap (easy fix $4)
no doubt there will be more to come...it is a 6.0
Shotgun_girl is offline
post #4 of 8 Old 03-09-2012, 06:42 PM
Another 6Slow
bouboy02's Avatar
Glad to see someone has a positive attitude
If you can hook up a code reader to it, im sure we can figure out your issue. I would test your FICM and make sure thats ok and then go from there.
2007 F-350 Motor built by Hostile Diesel, Transmission built by River City Diesel, Compounds built by Cutting-Edge Diesel
bouboy02 is offline
post #5 of 8 Old 03-10-2012, 02:42 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
If only it were THAT simple. Far too often, too many people tend to think that it's as simple as "hook the machine up and it will tell you what's wrong with it". For what it's worth, I've had more than my share of vehicles that have come in with no logged codes, but have had issues that were solely dependent on experience to repair.
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #6 of 8 Old 03-10-2012, 04:02 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
you should try and put a fuel gauge on it that will pass fuel through a clear hose back to fuel tank. start it and rev it ti 2k rpm if it get bubbles in fuel then you have to isolate side. with baloon test for both fuel feds from heads. but i think you either have a cracked head or cracked injector cup. they both will allow exhaust to get into fuel. ive even seen bad copper rings on bottom of injector go bad and exhaust blow past fuel ring. ive even seen bad injector do same thing!
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #7 of 8 Old 03-10-2012, 04:18 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
I've seen many many injectors leak combustion gas into the fuel system starving that bank of fuel and eventually stalling the truck. The most common repair is to isolate the bank then replace all of the injectors. injectors fired with no fuel in them will have suffered internal damage as the plunger will bottom out in the barrel.
you could try removing all of the glow plugs one at a time and cranking to see which cyl is putting combustion gas into the filter housing
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #8 of 8 Old 03-11-2012, 10:47 AM
That is exactly what mine is doing....not a code to be found.
Nikki
2004 6.0 F350 FX
Straight pipe
AFE cold-air intake
Sinister EGR delete
SCT tuned
Blue spring
6.4 Banjo Bolts
two injectors
2 alternators
oil cooler
IRP valve & HPOP
gasket on turbo
