Fuel gauge reads full - Ford Powerstroke Diesel Forum
Old 03-09-2012, 11:50 AM
Huffing Diesel Fumes
Ok so my fuel gauge reads full all the time when the key is on. If I disconnect the battery and then turn the truck on the gauge will rise slowly to full. I checked the wires going to the gauge and the reading was 169ohms I had about 150mi since fill up when I checked the ohms. Anyone know is there anything else I should check before buying a new fuel sender?
Old 03-14-2012, 11:34 AM
Anyone?
Old 03-15-2012, 07:35 AM
possible the fuel sender got stuck. ive seen some fuel sending units where the float gets stuck at X point in your case the full position. and since its stuck it wont change, just a start since ive seen it happen before in the 6.0
Old 03-15-2012, 08:45 AM
Yeah my fuel gauge is acting up also on my 04 250 it reads 1/4 tank and its empty, ask me how I know, anyhow its on my list to fix as im pretty sure its the float assembly in the tank. When I fill it up it takes a 30 seconds for the gauge to react and to show it being full.
David
Old 03-15-2012, 12:39 PM
So I should go ahead and replace the fuel sender? That's what I was planning on doing just wanted to see if anyone would think of anything else to check.
Old 03-16-2012, 04:53 AM
I have the same problem on my 03 6.0 long bed. I figured it was the fuel sender, but those bastards are expensive so Ive just been using the odometer.
Old 03-16-2012, 06:24 AM
Yeah that's what I have been doing for over a year now. I would like to fix it though.
Old 03-18-2012, 05:49 PM
wish mine read full all the time.....i have the opposite problem.
Old 03-18-2012, 06:56 PM
fuel guage
Sounds as if your sending unit is stuck. Try 3/4 tank of fuel and a rough road see if the fuel moving around in tank will break it loose.
Old 03-18-2012, 06:57 PM
Yeah I have the opposite problem. Mine always reads empty.
