3 trouble codes...FML
Well I bummed my friends diablo programmer and hooked it to my truck to check stuff out and found out I had 3 trouble codes....
P0266 cylinder 2 combustion/balance P0299 turbo/super charger underboost P0603 powertrain control module keep alive memory error Im not sure what all of them mean but I called the ford stealership and he said you cant tell just from the codes you have to diagnose it. So why would they bother putting trouble codes on it if they don't tell you anything? Any info will help thanks. Last edited by RTR stroker; 03-09-2012 at 03:04 PM. |
to the top
P0299 EP Turbo/Supercharger Underboost EP actual is less than commanded P0603 PCED Powertrain control module keep alive memory (KAM) error Faulty connection, faulty PCM This may help on the 299 On the 603 did you have the batteries remove for some time to have them checked or Look at page 66 here http://www.fordtechservice.dealercon...03-25-Book.pdf 2 stroker |
A code doesn't tell you to repl a part. It just gives you a direction to go in. There are several things that could cause those codes. How's the truck run? Does it miss, run rough, lack power, blow any smoke? What color smoke. When does it act up?
It surges i guess when its cold and then after it warms up a bit it runs pretty good but it does feel like it misses when i stop at a red light. And the truck has felt very sluggish latley.
That's not that bad.
Cylinder 2 might be an injector or wiring harness. Turbo code could be stuck VGT, or bad EBP sensor. Last is cause you probably DC the batts and the PCM lost power. |
Ok that makes me feel better..I just changed my batteries.
ok talked to the dealership they said they have a 75.00 diagnostic fee then its like 75 an hour plus whatever they decide to jack the price of parts up too. So i called another diesel shop up around here he said they charge 65 an hour and i said if worse comes to worse and you have to change the injector how much are we looking at and he said 550 and a little more if its on the passenger side (which i already told him 3 times its number 2 and its on the drivers side). Just wondering if that seems like a fair number or not i felt like it was a random high number he just threw out there.
P0603 PCED Powertrain control module keep alive memory.
Did you have both batteries out at one time if you did it will give you this code. may want to try some REV-X Oil Additive | Diesel Fuel Additive | High Performance Oil Have you checked your FICM Info here http://www.fordtechservice.dealercon...FICM_Guide.pdf and here http://swampsdiesel.com/site/install...ge_Testing.pdf Testing the FICM 2 stroker |
yea both were out at the same time, and i just dropped the truck off at the shop and they are going to test my ficm and figure out if my injector is out or if its the injector harness or w/e it is. He said if the ficm is bad then he will give it to me to send it off and get repaired while they work on the truck.
