2006, Flashing Tow/Haul light and Tach is barely working. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-28-2012, 05:44 PM Thread Starter
I have a 2006 6.0 liter that the tow/haul light is flashing. My Tach just started barely working, it is moving but won't go above 1000 rpms at all (my scan gauge is showing normal rpms). I also have an ABS and an Airbag light, not sure if these are all because of the same issue or not? The only CEL I am getting is 403 and 405 (EGR Delete). Once in a while I get a PO720 as well.
Does anyone have any ideas?
Power_Stroke_11 is offline
post #2 of 7 Old 02-28-2012, 05:50 PM Thread Starter
Also it will not shift into overdrive.
post #3 of 7 Old 02-29-2012, 04:00 AM Thread Starter
I think the previous owner put a tuner on this truck, is it possible that these issues could be caused by that and I just need to get the ecm reflashed.
post #4 of 7 Old 02-29-2012, 04:16 AM
jesilvas's Avatar
Quoted: 3 Post(s)
With all those different issues, it's hard to tell. Maybe loose battery connections, or something more complicated.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 7 Old 03-01-2012, 12:42 AM
A flashing tow/haul light indicates a tranny problem. {no overdrive }
As for the others could be a bad cluster module.
As the man said with all that going on kinda hard to tell.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #6 of 7 Old 03-01-2012, 07:39 PM
southend's Avatar
alternator, ground cable, positive cable, batteries...........
southend is offline
post #7 of 7 Old 03-04-2012, 09:54 AM
GDT
Alternator caused a ton of electrical problems for me. Check that, I chased other things when that was the real issue.
GDT is offline
