Crank No Start 2003 F-250. No base oil pressure.
Not getting any oil pressure while cranking, and the oil filter housing does not fill with oil while cranking and having someone push down on the valve.
What is the best way to determine if it is a bad oil pump or a bad pickup tube? Is there something else i could be missing? |
I seriously doubt that it would be the pickup tube, unless you have been inside the oil pan for any reason. It's just a tube that sits there and does nothing, plus I have never heard of the pickup tube being a issue in the 6.0. I have heard of the LPOP going out though.
What happened to it? Did you do any work to it? Going down the road when it died? I'm not trying to insult you or anything but, is it full of oil? Sent from my tab using the keyboard. |
IPR valve screen...
hrmm, IPR valve is not too bad to get to, but i guess i don't understand why that would cause a loss of base oil pressure. please elaborate. |
LPO somewhere.
Have you pulled the pressure regulator to see if oil pumps out? |
The IPR Valve, or is there a LPO pressure regulator too?
The press fit ball on the high pressure pump will allow a big enough leak to cause no base oil pressure. That is probably the most common cause
yes, but is there any way to test before ripping it out? 7 hours of labor + gasket sets is a pretty big risk.
and on the above post about the regulator can some one please explain in detail how to test for this issue. When starting while oil filter is out the housing fills up but drains back out without having to press the spring down. we pulled one out of a wrecked truck and all that we came out with was a threaded cap with spring. Is that all there is to the regulator? I would have figured there was something on the spring that would be a moving part. Thanks for any help we are stumppped. |
Ok, lot's of confusion on this thread. For the OP's issue, I think it's a low pressure oil issue. Yes, a large high pressure oil leak will cause the oil pressure gauge to not move up, but the way to determine if it's a low or high pressure oil leak is to pull the oil filter and crank it. If oil start pumping into the filter housing then you have a high pressure issue. If no oil pumps in then it's a low pressure problem.
Common possible causes could be issues with the pickup tube, faulty low oil pressure regulator, or oil pump/front cover issues. I would start with pulling the low pressure oil pressure regulator and checking that. I had one the other day that had an injector inlet snap ring come apart, and a piece of the snap ring managed to get into the oil pressure regulator and hold it open causing no low oil pressure. Pull the regulator out and make sure it's moving freely and not scored up. If all that looks good I'd pull the low pressure oil pump and inspect that next. |
| Tags |
| lpop, no start, oil pressure, oil pump, pickup tube |
