Cold start issues. Should I plug in??? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-23-2012, 12:19 PM Thread Starter
Kyleu890's Avatar
I have a 2004 f350 6.0 bone stock, egde insight is all. 126,000 miles and she runs like a top when warm. After sitting all night I'll walk out, cycle the glow plugs 1 time and fire her up. She will stumble for a minute then clear up. When I check the codes it throws p0671. I will erase the code and it won't throw it all day, until the next morning after sitting all night. Also after first cold start, through out the rest of the day it starts perfect, no stumble nothing. If its a glow plug, are the tricky to replace?
04 ccsb f350 little red rip! Previous truck
05 ccsb f250 currently bone stock no plans to change it.
Kyleu890 is offline
post #2 of 9 Old 02-23-2012, 01:33 PM
P0671 GPCM Cylinder 1 glow plug circuit Circuit open, short to ground, short to voltage, faulty glow plug
Do you have the Edge CTS or the older Edge like mine, the CTS will tell FICM voltage need 45v but should be 48v don't think it is a glow plug may be wrong check wires to number 1
May want to check the FICM because weak or bad battteries will kill it.
FICM Repair.com - Your Source for FICM Repair My choice or here
6.0 DIESEL POWERSTROKE FORD FUEL INJECTOR CONTROL MODULE FICM F250-550 ECONOLINE | eBay
Info here http://www.fordtechservice.dealercon...FICM_Guide.pdf
and here http://swampsdiesel.com/site/install...ge_Testing.pdf
Testing the FICM
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #3 of 9 Old 02-23-2012, 02:01 PM Thread Starter
Kyleu890's Avatar
I have the cts ficm at cold start is 42-45 but after about a min of running goes up to 48-49! Battery voltage ranges from 13.4- 14.4 mainly higher 13's. Also when it gets cold should I plug it in? I've been told by a friend that 6.0's get lazy if you plug them in. The. When ever its cold and you don't plug it in, it won't want to start
Kyleu890 is offline
post #4 of 9 Old 02-23-2012, 10:07 PM
I think you are starting to have FICM problems that is the first signs low voltage plus by plugging it in helps the cold start do some reading here Swampsdiesel is a good one.
2 stroker
Delo ELC Coolant
3" dp 4" exhaust
Tymar Intake
post #5 of 9 Old 02-25-2012, 01:08 AM Thread Starter
Kyleu890's Avatar
Is it true that 6.0's get lazy if you plug them in though? Like once you plug them in, the truck won't want to start in cold temps unless it's plugged in?
Kyleu890 is offline
post #6 of 9 Old 02-25-2012, 02:57 AM
van-boy's Avatar
trucks dont think, they either do or dont. they cant get lazy. if you are having a cold start issue its got to be something else. on a side note, i always plug my truck in with a timer when it gets below freezing. just easier on the engine.
van-boy is offline
post #7 of 9 Old 02-25-2012, 12:47 PM Thread Starter
Kyleu890's Avatar
I don't know haha. I know my truck hates me sometimes! But thanks I just heard that and wasn't sure if it was true or not! Thanks for all your help.
Does the low voltage mean I need a new one or is it still possible to have it rebuilt?
Kyleu890 is offline
post #8 of 9 Old 02-25-2012, 02:09 PM Thread Starter
Kyleu890's Avatar
Also if the ficm is going bad, will the voltage be that low for every start through out the day? Because when I start her warm the voltage is right around 48-49 volts
Kyleu890 is offline
post #9 of 9 Old 02-25-2012, 04:05 PM
You be the judge when cold low voltage when warm high voltage
Ed at FICM Repair.com - Your Source for FICM Repair is the man he will update parts as needed give him a call, he is on the forum sometime. Ford wants $1100 to $1400 so i would go to Ed.
2 stroker
Delo ELC Coolant
3" dp 4" exhaust
Tymar Intake
