Blue Spring Question - Ford Powerstroke Diesel Forum
Old 02-21-2012, 08:51 AM
So I just put in the new blue spring....and just to clarify, it is the OEM one from Ford. My question is this: While I was changing it out, I noticed a green o-ring in the pack. The only place I saw a green o-ring was in the fuel filter housing itself. I put it on the "guide" the you slip the fuel filter over when putting it in the housing. Not sure if that is being clear enough or not. The reason I ask is because the o-ring that was already there seemed to be a little beefier than the one i put in which was in the kit. I searched through the forum and couldn't find an answer, and none of the instructions i found really seemed to go into detail about the o-ring install. Haven't driven it yet, but it seems to be running fine at idle. I don't have a fuel pressure gauge yet, but I do have an Edge Insight CTS. Can somebody with knowledge on this please chime in. Thanks in advance.
Old 02-21-2012, 02:42 PM
I'm pretty sure the greenish oring is for where the return line connects to the adapter. It sits inside the end of the adapter. Mine didn't fit so I left the old one on there. Someone correct me if I'm wrong but I'm pretty sure that's where it is ment to go. Hope this helps
Old 02-21-2012, 02:55 PM
It does. It lets me know that I prob put the wrong o-ring in the fuel bowl. Weird that it doesn't seem to be making a difference though. Guess I need to find a new o-ring set. Thx
Old 02-21-2012, 03:00 PM
Did you throw your old o-ring out?
Old 02-21-2012, 03:08 PM
No, I still have it for reference. Problem is I chopped it up pretty good when I was taking it off.
Old 02-21-2012, 03:33 PM
Dang, that sucks..I'll look around and see if I can help you find where to get one.
Old 02-21-2012, 03:50 PM
I appreciate it. I'm gonna hit up napa tomorrow and see if they have anything. Only thing I found so far was the whole kit which was like $40. Thx again.
Old 02-21-2012, 05:12 PM
Just curious, does the factory ford kit come with installation instructions?
Old 02-21-2012, 05:21 PM
No, it does not. It comes with a very generic pic (that you can't see what is what) and thats it.
Old 07-09-2012, 08:19 PM
Madruga
I had same problem once I got my blue spring kit i thought same and poked out my green o ring on fuel housing standpipe.... well i searched and found you so maybe this will help others too... dealer wanted $40 for entire standpipe, I went to NAPA and found a fuel o-ring set, 1 was perfect, was $8 for entire box. Same Size a slight bit smaller but thats fine since old one is stretched out.
