I have a 2006 F-250 with 77,000 miles. Whenever I get above 50 mph and give it light to medium throttle my truck hesitates and bucks, but then takes off without a problem. There is no problem at all when I burry the pedal.
I took it to a local diesel shop that has done work on truck before and is very reputable. They first said it sounded like a sticking vein in the turbo. So they rebuilt it but it was still happening. They then said it was a torque converter so I had them replace that. When I first go the truck back it seemed to be fine but then after about 300 miles the hesitation/buck came back and it seemed to be worse. Any suggestions???? |
Check your tps is working properly. The tranny compares the signals from tps [throttle position sensor] & the VSS [vechile speed sensor] to determine which gear it is supposed to be in. You may be unable to stay in high gear.
Thanks I will mention this to them today when I drop the truck in.
I have similar symtoms, my #4 injector tested bad.
I have the same problem i cant figure it out my truck has about 183000 on it.......let us know what they have to say
Mike |
I have the same issue when cold, it's strict ion in the spool valve on the injectors, but it goes away when warm
Injector 3 and 7, fortunately they are both on the same side.
