Oil in coolant resevoir - Ford Powerstroke Diesel Forum
Old 02-20-2012, 04:30 PM
Well the title says it all... My truck has been pushing a little water out lately and tonight when I checked the coolant level I found oil around the cap :/. I just did an egr delete and head studs and new gaskets less then 5,000 miles ago any ideas?
Old 02-20-2012, 04:35 PM
Powerstroke Techie
Feedback Score: 3 reviews
sounds like your oil cooler has failed. was your egr cooler leaking previously?
Old 02-20-2012, 05:12 PM
Yea I had to do an egr delete so I did the head studs while I was at it but I didnt change the oil cooler. So thats what I was leanin towards too.
Old 02-21-2012, 08:10 PM
I learned the hard way too! I did my head gaskets and studs about 5k ago too. My oil cooler is plugged big time. It definately sounds like your cooler ruptured internally. I'm in the process of doing my cooler right now. Not too bad of a job to do, major PIA is removing the turbo. Once turbo has been removed you have plenty of room to work on it. I guess next time if I ever do a head gasket job again on another truck, replace oil cooler while in there. My lessoned learned!
