06 Powerstroke with trouble codes, 720, 403, and 405 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-20-2012, 10:49 AM Thread Starter
Truck has an egr delete with no egr at all, and the cat has been removed. I'm assuming the 403 and 405 have to do with the egr, please correct me if I am wrong. What is the 720? It showed up when I first got in the truck to test drive it but has not shown back up.
Thanks for any info you can share.
Power_Stroke_11 is offline
post #2 of 4 Old 02-20-2012, 11:52 AM
P0403 EGR Exhaust gas recirculation control circuit Open circuit, short to ground, short to voltage, faulty valve, faulty PCM
P0405 EGR Exhaust gas recirculation sensor A circuit low Voltage below a specified range
PO720 Output Shaft Speed Sencer Circuit
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #3 of 4 Old 02-20-2012, 12:11 PM Thread Starter
Ok its seems the egr is the first but what does that 720 code mean? Can anyone dumb it down for me?
post #4 of 4 Old 02-20-2012, 04:25 PM Thread Starter
I have done some reading about the 720 code, is it possible that this was caused by dead betteries? I've seen people say that alternator issues have some how caused this issue and when we went to start the truck the batteries were dead.
