only when cold - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-20-2012, 09:27 AM Thread Starter
STROKEDIS's Avatar
only when cold
ok so a few weeks ago some a hole decided he needed my gas cap more than i , just the other morn wife says truck sputters and wants to die when she puts in reverse . yesterday i bought a gas cap and changed both fuel filters they say they are water separating filters but it just looked like a regular element to me . so im hoping this was my issue .ity only did this when cold soon as it warmed up it was fine!!!!STROKEDIS
05 sd ,banks six gun tuner ,arp head studs ,bullet proof diesel egr cooler,upgraded fuel pump,upgraded fuel regulator banks air filter , turbo back 4 inch exhaust, 8 " lift 37's with 4.56 gears
STROKEDIS is offline
post #2 of 6 Old 02-20-2012, 09:32 AM
jimmyv13's Avatar
Quoted: 46 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
What is your FICM voltage on a cold start?
2005 F250 CCSB Lariat FX4
4" MBRP Turbo Back*Sinister Coolant Filter*SRL+*'10 Tailgate*Dicad EGR delete*Premium EdFICM*Powerslot Rotors*Hawk Pads*Riffraff boots*DIY CCV*ARP's*'10 Tails*N-FAB Steps*'12 Rear Bumper*Dashboss*Pioneer DVD*'08 Trans Pan
*Bullitt y-pipe*'14 PE PF Mirrors*Fox 2.0 IFP*'08 Diff Cover
jimmyv13 is offline
post #3 of 6 Old 02-20-2012, 09:44 AM
As stated need to check your FICM, how old are your batteries number one kill. The price of a new ficm around $1100 from Ford or you can have your rebuilt at BPD Repair Ford FICM Module for $300
or--- FICM Repair.com - Your Source for FICM Repair My choice or here
6.0 DIESEL POWERSTROKE FORD FUEL INJECTOR CONTROL MODULE FICM F250-550 ECONOLINE | eBay
Info here http://www.fordtechservice.dealercon...FICM_Guide.pdf
and here http://swampsdiesel.com/site/install...ge_Testing.pdf
Testing the FICM
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #4 of 6 Old 02-20-2012, 12:00 PM Thread Starter
STROKEDIS's Avatar
it fires right up idles like its suppose to and if i give it a little gas it responds ,then you put in gear and it seems fine then starts to stumble . once its wartmed up for a bit its fine!!! how do i go about checkin voltage at ficm!!STROKEDIS
post #5 of 6 Old 02-20-2012, 12:16 PM
sounds like stiction to me. try 5w-40 synthetic oil next change and look into rev-x additive. the synthetic helps but rev-x works really well in almost every case.
05 F250 FX4 Supercab XLT LB 6.0 Torqshift ESOF, Boss V-Plow, Diamond plate running boards and toolbox, 105gal Diesel Tank 15GPM pump, 130+k Blue Spring Update, Sinister Coolant Filtration Scangauge 2
joe_r_dog is offline
post #6 of 6 Old 02-20-2012, 12:31 PM
You said it does it when cold now warm it could be stiction now
http://alliantpower.com/pdf/APTB-0109-watermark.pdf
Ckeck the ficm (the big square box above) with the arrow in it
2 stroker
Delo ELC Coolant
3" dp 4" exhaust
Tymar Intake
