Battery Light flickering on full throttle - Ford Powerstroke Diesel Forum
Old 02-19-2012, 06:35 PM
My 03 6.0 has the battery charge light flickering when Im at full throttle the lights actually dim a little to? checked wires and everything and it all looks good.
Old 02-19-2012, 06:37 PM
You need to have the batteries and alternator tested. Make sure the batteries are tested as individuals.
Old 02-19-2012, 06:38 PM
mine did that about a month ago. Batteries checked out ok. Changed the alternator and the light hasnt come back. Went from 12v to 14v on my edge.
Old 02-19-2012, 09:41 PM
Need to get it fixed ASAP because it will kill your FICM new from Ford $1100 to $1400 or send yours in for repairs about $300
FICM Repair.com - Your Source for FICM Repair
2 stroker
Old 02-20-2012, 07:51 PM
What the alternator? or the fcim? I'm also having problem with my heater fan blowing fuse and my right turn sugnla blowing fuse
Old 02-20-2012, 07:54 PM
Get a new alternator
Old 02-20-2012, 10:00 PM
alternator
https://www.dcpowerinc.com/category/...rd&model=F-350 Super Duty
FICM
If you are blowing fuses you have a short to ground someplace.
2 stroker
Old 02-22-2012, 08:10 AM
does anyone know where or if the wires run next to eachother? the heater and right turn signal..
Old 03-20-2012, 02:56 AM
On the original post...run a new ground from the alternator bracket to the frame ground.
